Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2015-08-12T17:54:58+00:00
    Just hoping to solve this problem I upgraded to win10 however the problem was still there.
    most probably it is a hardware issue due to overheating.
    It seems Toshiba used a defective conexant product
    2015-08-14T09:47:59+00:00
    I've been following this thread on and off for a few years now ever since I ran into the issue way back.
    Having updated to Windows 10 a few days ago I've gone about a week or more without having audio issues (Cortana sometimes stopped listening to me and responding properly in general but that issue seems to be gone for days now).
    Until today, when I booted up and this nightmare came back. I used to be able to restart the audiosrv service back on Windows 8.1 to fix it temporarily, but when I try that now it gets stuck on the "stopping" state.
    I've tried getting the latest drivers from the realtek site, disabling exclusive mode for the device and setting it back to 16bit 192000Hz from the 24bit thing it was on before. I'll get back to this thread later to let you guys now if the problem persists.
    2015-08-18T13:56:34+00:00
    Happened two or three times since my last post. Damnit microsoft.
    2015-08-19T09:15:54+00:00
    The same sound problem has started with me when I upgraded to 10 it was fine on 7. Have tried lots of things but no luck thinking of going back to 7 while I still can
