Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2014-10-30T15:35:18+00:00
    Followed Azam K's instructions. (my sound was not working at the time)
    When i got to the Advanced Tab, it gives you format options. Mine was on 24 bit, hit test and it did not work. I set it to 16 bit 192000 and hit test and it worked. Has worked ever since :)
    2014-10-31T18:47:46+00:00
    Please run dxdiag and save a log. Then post this information so we can see your computer and audio hardware information. ------------------ System Information ------------------ ------------- Sound Devices ------------- --------------------- Sound Capture Devices --------------------- Thanks, Chris
    Hello Chris,
    im using windows 7 ultimate & sound suddenly stops workings after 10-15 mis... below is the info.. please help
    System Information
    Time of this report: 11/1/2014, 00:13:40
           Machine name: YESHWANTH-PC
       Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
               Language: English (Regional Setting: English)
    System Manufacturer: Sony Corporation
           System Model: VGN-NR38M_S
                   BIOS: Ver 1.00PARTTBL
              Processor: Intel(R) Pentium(R) Dual  CPU  T2390  @ 1.86GHz (2 CPUs), ~1.9GHz
                 Memory: 2048MB RAM
    Available OS Memory: 2038MB RAM
              Page File: 839MB used, 3237MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7600.16385 32bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
            Sound Tab 1: No problems found.
              Input Tab: No problems found.
    Sound Devices
                Description: Speakers (High Definition Audio Device)
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0262&SUBSYS_104D2800&REV_1001
            Manufacturer ID: 1
                 Product ID: 65535
                       Type: WDM
                Driver Name: HdAudio.sys
             Driver Version: 6.01.7600.16385 (English)
          Driver Attributes: Final Retail
                WHQL Logo'd: Yes
              Date and Size: 7/14/2009 05:21:47, 304128 bytes
                Other Files:
            Driver Provider: Microsoft
             HW Accel Level: Basic
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    2014-11-19T14:17:35+00:00
    Audio stops working but works after a reboot- the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem  I'm running windows 8- Previous listed solutions don't work since they are for windows 7 or vista.... HELP!
    2015-01-05T14:31:40+00:00
    Ideas:
    I faced this similar issue around 6 months back. First of all let me tell you the reason why many of windows users are facing this problem. If you go to -->> ( Control Panel\System and Security\Windows Update\Change settings), you might see that that you have selected "Install updates automatically(recomended) for your PC. Because of this, every day new window updates are installed for your PC . And one of the window update is affecting your system sound. Windows till now dont have a fix for this one. So the best solution right now is to uninstall all the updates of last 2-3 weeks if you started facing this problem from last one week and change to "install updates option" to "Never check for updates".Your system will be ok after you do this.
