Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2014-01-03T18:02:55+00:00
    Same problem, it works only after I restart the windows audio service (net stop/start audiosrv)
    System Information
    Time of this report: 1/3/2014, 19:58:40
           Machine name: USER-PC
       Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
               Language: English (Regional Setting: English)
    System Manufacturer: TOSHIBA
           System Model: Satellite C655D
                   BIOS: InsydeH2O Version CCB.03.60.341.60
              Processor: AMD E-300 APU with Radeon(tm) HD Graphics (2 CPUs), ~1.3GHz
                 Memory: 4096MB RAM
    Available OS Memory: 3686MB RAM
              Page File: 1098MB used, 6272MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7601.17514 32bit Unicode
    Sound Devices
                Description: Speakers (Conexant SmartAudio HD)
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_5069&SUBSYS_1179FDE8&REV_1003
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                Driver Name: CHDRT64.sys
             Driver Version: 8.36.0000.0000 (English)
          Driver Attributes: Final Retail
                WHQL Logo'd: Yes
              Date and Size: 10/21/2010 14:37:46, 1306240 bytes
                Other Files:
            Driver Provider: Conexant
             HW Accel Level: Basic
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
                Description: Internal Microphone (Conexant SmartAudio HD)
      Default Sound Capture: Yes
      Default Voice Capture: Yes
                  Cap Flags: 0x1
               Format Flags: 0xFFFFF
    2014-01-28T02:10:56+00:00
    You can use Microsoft sound fix it,i sure after that your problem will be resolved...http://support.microsoft.com/mats/audiorecording/
    I hope this is helpful for you....
    2014-01-29T18:12:43+00:00
    It doesn't work with Win8...
    2014-03-21T00:25:01+00:00
    Go to your search bar.
    Type 'Services.msc'
    Find 'Windows Audio'
    Stop and restart the service.
