Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2012-05-25T03:49:10+00:00
    Same issues here. In fact, a simple Google of “Windows 7 audio stops”will show that this is a widespread and very real issue, although calling it an “epidemic” might be a bit extreme.
    As for me, 64-bit Win 7 Home Premium, Line 6 GuitarPort, everything with current drivers. Using the built-in RealTek excuse for a sound card for many months (November to April) I had no issues whatsoever, but using the GuitarPort (a USB audio device) I could get maybe four days of audio, whether or not I disabled the onboard sound in BIOS. All drivers are current. The GP works flawlessly on my old XP system, and fine on this system running an old 64-bit Ubuntu. It is not a hardware issue.
    Stopping and restarting the audio service does not work, whether through the Management Console or a NET command (hey, you never know). All the standard indications that there is an issue fail to alert me – as far as the system is concerned, there is no problem, regardless of the actual facts (although the Device Manager hangs when I try to disable the device). Setting the audio service to automagically restart on failure does not work. Did I mention that all drivers are current?
    KB 2484031, “A USB audio device stops playing audio in Windows 7” seemed relevant, especially since my system hangs a while before rebooting after dropping audio, but there is no applicable hotfix. I applied the recommended updated KB hotfix, 2529073, but that was disastrous – I have to close out of whatever audio app I’m using (WinAmp for music, VLC Media Player – both of which, like my drivers, are current) to get any sound at all, and it takes a good ten seconds before the audio starts. Worse yet, my three or four days of usable audio has now turned into three or four hours. Ah well; I was wondering why “Binary files in some USB drivers are not updated after you install Windows 7 SP1 or Windows Server 2008 R2 SP1” would have anything to do with “A USB audio device stops playing audio in Windows 7.”
    In summary: This is not a hardware issue (the hardware works fine outside of Windows 7). Nor is it a driver issue (unless you want us to believe a conspiracy among the makers of USB audio devices). It is an OS issue. Many people have the same issue, and we’re not as silent as our devices.
    2012-06-17T17:51:16+00:00
    I have the same problem:
    After some hours the sound repeats itself and after closing either windows mediaplayer or youtube the sounds stops completety and it doesn't come back untill a reboot.
    I tried using this:
    There is actually a very easy way to fix this problem ..
    You need to restart the "Windows Audio" service, and all comes back fine.
    I made a one-liner shortcut on my desktop (with powershell) to do this.
    %SystemRoot%\system32\WindowsPowerShell\v1.0\powershell.exe -Command "Restart-Service AudioSrv"
    But when i do, Powershell says:
    Restart-Service : Service 'Windows Audio (AudioSrv)' cannot be stopped due to the following error: can't open Srv on the computer .
    At line:1 char:16
    • Restart-Service <<<<  AudioSrv
    • CategoryInfo          : CloseError: (System.ServiceProcess.ServiceController:ServiceController)
    ], ServiceCommandException
    • FullyQualifiedErrorId : CouldNotStopService,Microsoft.PowerShell.Commands.RestartServiceCommand
    Here is my system information:
    System Information
    Time of this report: 6/17/2012, 19:28:52
    Machine name: SEFASAGDIC
    Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
    Language: Dutch (Regional Setting: Dutch)
    System Manufacturer: Packard Bell
    System Model: imedia S3720
    BIOS: Default System BIOS
    Processor: Intel(R) Core(TM)2 Quad CPU    Q8300  @ 2.50GHz (4 CPUs), ~2.5GHz
    Memory: 4096MB RAM
    Available OS Memory: 4096MB RAM
    Page File: 2604MB used, 5584MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7601.17514 64bit Unicode
    Sound Devices
    Description: Luidsprekers (SRS Audio Sandbox (WDM))
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: SRS\SSCFilter
    Manufacturer ID: 65535
    Product ID: 65535
    Type: WDM
    Driver Name: SRS_SSCFilter_amd64.sys
    Driver Version: 1.07.0000.0000 (English)
    Driver Attributes: Final Retail
    WHQL Logo'd: Yes
    Date and Size: 7/26/2007 10:28:54, 55040 bytes
    Other Files:
    Driver Provider: SRS Labs, Inc.
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Description: Speakers (Realtek High Definition Audio)
    Default Sound Playback: No
    Default Voice Playback: No
    Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1025027C&REV_1002
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: RTKVHD64.sys
    Driver Version: 6.00.0001.5898 (English)
    WHQL Logo'd: Yes
    Date and Size: 7/20/2009 12:52:38, 1831968 bytes
    Other Files:
    Driver Provider: Realtek Semiconductor Corp.
    Cap Flags: 0xF1F
    HW Memory: 0
    Sound Capture Devices
    Description: Microphone (Realtek High Definition Audio)
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x1
    Format Flags: 0xFFFFF
    Description: Stereo Mix (Realtek High Definition Audio)
    Default Sound Capture: No
    Default Voice Capture: No
    Cap Flags: 0x1
    2012-07-02T01:01:55+00:00
    Update 9/16/2012: To skip my rant just scan down to the bold and underlined solutions. :-)
    This has been happening to my PC too. It started over a year ago, but was fixed after I reinstalled Windows 7 Professional 64-bit last year (for a different reason). The problem appeared again a couple months ago. Sound stops working after some time (30 mins - a few hours) but works after a reboot. It is almost definitely not a sound driver or hardware issue. It is a problem with Windows 7. If sound never works, then the first thing I would suspect is the sound driver, but since most of us seem to have our sound drivers up to date and audio works at bootup, then that isn't the reason for the audio problem. When audio isn't working for me and I shut down or reboot the PC, as Windows is shutting down, I hear a low volume static pop (with my headphones) as if Windows has halted or stopped the offending program or service that is hanging the audio. This leads me to believe that the audio would actually work again if I could stop Windows from shutting down. I just tried the following method to reinstate the audio without restarting and it has so far worked for me. Go to Device Manager, expand "Sound, video and game controllers", right click "High Definition Audio Device" and select Disable. Then right click on it to Enable it again. I opened an mp3 in Winamp and the audio returned. (I wasn't using Winamp before when the audio stopped. I noticed the audio stopped when trying to start a game). I happend to pause the song and just left it like that for maybe 20 mins. I unpaused it and the audio was gone again. Performing the previous steps to reinstate it did not work at first, so I also Disabled the "AMD High Defintion Audio Device" also located (for me) in "Sound, video and game controllers" and Enabled it again and the sound returned. (See update at the bottom of this message).
    I have also noticed that sometimes when doing this method, Windows will ask if you would like to restart the computer for the changes to take effect. The changes will still take effect if you answer no to rebooting. I realize this may not work for some people but it is worth a try. I also realize this is not a solution to the root cause of the problem and MS needs to fix this. I highly doubt they will though. I have not noticed pausing or muting audio to consistently reproduce this failure before today, but maybe that can be one of the things that cause this issue. After reading most of the posts in this thread, I believe that there are a number of different applications that can cause this audio issue. But, I believe that Windows 7 is the reason behind it. Like another person posted previously, searching Google shows this to be a fairly common problem. The superb Windows XP and the craptastic Vista do not have this problem.
    I am pretty sure MS knows this is a Windows 7 issue, but apparently either doesn't know how to fix it and/or is unwilling to admit it is their problem. Tech support just tries to help us with basic things. They aren't the ones actually making patches to the OS. Plus, it just seems as though MS tech support would try to blame the sound driver to pass the buck onto somebody else. Their next step is to stall by asking people to post statistical and diagnostic reports of their PC's. Over time, they hope people will just learn to live with this annoyance. This thread started Oct 28,2009 and the last comment by MS was made March 3, 2010, yet people have been posting somewhat continuously into 2012. I have not seen anything regarding a solution to this problem from MS besides the first reply or updating sound drivers. That is very poor support, both from Tech and from the software engineers responsible for bugs in the OS.
    Update 7/1/2012
    I just repeated the audio problem again. I left a song paused in Winamp for another 20 - 30 mins and the audio was gone again. I would also like to add a clarification to the method I previously posted. To get the audio back, I had to first close Winamp and then Disable and Enable the "High Definition Audio Device". Leaving Winamp open while disabling and enabling the "High Definition Audio Device" did not work. (Update: So basically, close down any program that is trying to play audio first, then disable and enable the audio device in Device Manager.)
    I created a Device Manager shortcut on the desktop, as I will be needing to use this "fix" a few times a week.
    I also tried the method posted by IvanMarshall back on May 24, 2011:
    {{{{"There is actually a very easy way to fix this problem ..
    That method did not work for me. I got an error message and didn't spend the time to debug it since the disabling and enabling the audio device method works for me.
  4. Deleted
