Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2012-03-20T22:36:20+00:00
    My audio definitely is being killed by sleep mode. Consistently have no audio after returning from sleep mode. Restart solves problem every time. Also video can be slow motion after sleep mode. Cannot see any setting options in power/sleep mode settings. Ideas?
    2012-03-23T07:38:13+00:00
    if your machine takes forever to shutdown because the audio stops working, i found a way to overcome the long wait. first, make sure some application is running, like a browser or something. now click shutdown in the start menu. you will get a dark screen showing you the applications that are running, and below, you will see "force shutdown". click on it. then click on "yes". your computer should take normal time to shutdown. the main idea of keeping the application running in the background is to allow you sufficient time to click on force shutdown. i figure, the long wait is because of the fact that the audio driver process is unable to get terminated normally.
    2012-05-24T12:59:40+00:00
    Man! it works, Its been long time but still I would like to thank you for this post... as it saves me a lot of time.
    2012-05-24T13:48:39+00:00
    Ideas:
