Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2011-06-17T11:45:01+00:00
    This solution works brilliantly for me - many thanks
    2011-08-09T11:35:19+00:00
    There is actually a very easy way to fix this problem ..
    You need to restart the "Windows Audio" service, and all comes back fine.
    I made a one-liner shortcut on my desktop (with powershell) to do this.
    %SystemRoot%\system32\WindowsPowerShell\v1.0\powershell.exe -Command "Restart-Service AudioSrv"
    Let me know how to create a shortcut in Windows 7 with PowerShell? (sorry but I do not know how), thanks for the solution, and please be very explanatory) :)
    2011-10-30T00:52:39+00:00
    This does nothing for me.   But, thanks for posting.
    2011-10-30T01:00:29+00:00
    Need Help!   Same Audio Problem!
    I have windows 7 64bit running a dell.  Pretty new/clean config.  Very religious about applying up to date ms patches....a little bit of a laggard with regard to dell & subsystem patches.
    Regardless, this all worked fine until about 2 months ago.  My symptoms exactly the same.   Sound works for a few hours then kraps out.
    I did not find the powershell scripting provided helped me.   And, I don't consider that a "Fix."   I consider it a workaround.
    The  only way I can get sound is to reboot.   I use sound in 70% of my computer usage (Skype, Youtube, and links to site with audio).     This is an egregious problem for me.
    I use Headsets as my default sound and occasionally set up speakers if I am going to watch a movie with a friend.
    Would really appreciate ANY suggestions/Help.
    Mark in Honolulu
    dxdiag txt output:
    System Information
    Time of this report: 10/29/2011, 14:36:55
    Machine name: KAMUELA
    Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
    Language: English (Regional Setting: English)
    System Manufacturer: Dell Inc.
    System Model: Inspiron 580
    BIOS: Default System BIOS
    Processor: Intel(R) Core(TM) i5 CPU         650  @ 3.20GHz (4 CPUs), ~3.2GHz
    Memory: 8192MB RAM
    Available OS Memory: 8120MB RAM
    Page File: 6191MB used, 10045MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7601.17514 32bit Unicode
    DxDiag Notes
    Display Tab 1: No problems found.
    Display Tab 2: No problems found.
    Sound Tab 1: No problems found.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
    Card name: NVIDIA GeForce GT 220
    Manufacturer: NVIDIA
    Chip type: GeForce GT 220
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_0A20&SUBSYS_069A10DE&REV_A2
    Display Memory: 493 MB
    Dedicated Memory: 1007 MB
    Shared Memory: 3582 MB
    Current Mode: 1920 x 1080 (32 bit) (59Hz)
    Monitor Name: DELL E2210H(Digital)
    Monitor Model: DELL E2210H
    Monitor Id: DELD031
    Native Mode: 1920 x 1080(p) (60.000Hz)
    Output Type: DVI
    Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver File Version: 8.15.0011.8634 (English)
    Driver Version: 8.15.11.8634
    DDI Version: 10.1
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 7/8/2009 19:37:00, 9480192 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71E3E-4960-11CF-D452-912602C2C535}
    Vendor ID: 0x10DE
    Device ID: 0x0A20
    SubSys ID: 0x069A10DE
    Revision ID: 0x00A2
    Driver Strong Name: oem57.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section017:8.15.11.8634:pci\ven_10de&dev_0a20&subsys_069a10de
    Rank Of Driver: 00E60001
    Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
    Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    D3D9 Overlay: Supported
    DXVA-HD: Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Current Mode: 1280 x 720 (32 bit) (60Hz)
    Monitor Name: DELL E2210H(Analog)
    Monitor Id: DELD030
    Output Type: HD15
    DDI Version: 10.1
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Vendor ID: 0x10DE
    Device ID: 0x0A20
    Revision ID: 0x00A2
    DXVA-HD: Supported
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description: Speakers (3- Logitech G35 Headset)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: USB\VID_046D&PID_0A15&REV_0303&MI_00
    Manufacturer ID: 65535
    Product ID: 65535
    Type: WDM
    Driver Name: USBAUDIO.sys
    Driver Version: 6.01.7601.17514 (English)
    WHQL Logo'd: Yes
    Date and Size: 11/20/2010 00:43:52, 109696 bytes
    Other Files:
    Driver Provider: Logitech, Inc.
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    Description: Microphone (3- Logitech G35 Headset)
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x1
    Format Flags: 0xFFFFF
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Device Name: Microsoft Hardware USB Mouse
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x045E, 0x00D1
    FF Driver: n/a
    Device Name: Natural® Ergonomic Keyboard 4000
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x045E, 0x00DB
    FF Driver: n/a
    Device Name: Logitech G35 Headset
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0x0A15
    FF Driver: n/a
    Device Name: HID-compliant mouse
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x2101, 0x0231
    FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    • USB Root Hub
    | Vendor/Product ID: 0x8086, 0x3B34
    | Matching Device ID: usb\root_hub20
    | Service: usbhub
    +-+ Generic USB Hub
    | | Vendor/Product ID: 0x8087, 0x0020
    | | Matching Device ID: usb\class_09
    | | Service: usbhub
    Gameport Devices
    PS/2 Devices
    • Microsoft USB Natural Ergonomic Keyboard 4000 (IntelliType Pro)
    | Matching Device ID: hid\vid_045e&pid_00db&mi_00
    | Service: kbdhid
    • HID Keyboard Device
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    • Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    • Microsoft USB Comfort Optical Mouse 3000 (IntelliPoint)
    | Matching Device ID: hid\vid_045e&pid_00d1&col02
    | Upper Filters: Point64
    | Service: mouhid
    • HID-compliant mouse
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    • Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 838.6 GB
    Total Space: 938.8 GB
    File System: NTFS
    Model: ST31000528AS ATA Device
    Drive: E:
    Free Space: 138.3 GB
    Total Space: 953.9 GB
    File System: NTFS
    Model: ST31000340AS ATA Device
    Drive: L:
    Free Space: 1519.6 GB
    Total Space: 2861.6 GB
    File System: NTFS
    Model: WD My Book 1140 USB Device
    Drive: D:
    Model: HL-DT-ST DVD+-RW GH50N ATA Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
    Drive: K:
    Model: ELBY CLONEDRIVE SCSI CdRom Device
    System Devices
    Name: High Definition Audio Controller
    Device ID: PCI\VEN_10DE&DEV_0BE2&SUBSYS_069A10DE&REV_A1\4&33B48940&0&0108
    Driver: n/a
    Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_04381028&REV_06\3&11583659&0&D8
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family 4 port Serial ATA Storage Controller - 3B20
    Device ID: PCI\VEN_8086&DEV_3B20&SUBSYS_04381028&REV_06\3&11583659&0&FA
    Driver: n/a
    Name: NVIDIA GeForce GT 220
    Device ID: PCI\VEN_10DE&DEV_0A20&SUBSYS_069A10DE&REV_A2\4&33B48940&0&0008
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 6 - 3B4C
    Device ID: PCI\VEN_8086&DEV_3B4C&SUBSYS_04381028&REV_06\3&11583659&0&E5
    Driver: n/a
    Name: Intel(R) H57 Express Chipset LPC Interface Controller - 3B08
    Device ID: PCI\VEN_8086&DEV_3B08&SUBSYS_04381028&REV_06\3&11583659&0&F8
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 5 - 3B4A
    Device ID: PCI\VEN_8086&DEV_3B4A&SUBSYS_04381028&REV_06\3&11583659&0&E4
    Driver: n/a
    Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_04381028&REV_A6\3&11583659&0&F0
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
    Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_04381028&REV_06\3&11583659&0&E0
    Driver: n/a
    Name: Intel(R) processor PCI Express Root Port - 0041
    Device ID: PCI\VEN_8086&DEV_0041&SUBSYS_04381028&REV_12\3&11583659&0&08
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
    Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_04381028&REV_06\3&11583659&0&D0
    Driver: n/a
    Name: Intel(R) processor DRAM Controller - 0040
    Device ID: PCI\VEN_8086&DEV_0040&SUBSYS_04381028&REV_12\3&11583659&0&00
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
    Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_04381028&REV_06\3&11583659&0&E8
    Driver: n/a
    Name: DW1525 (802.11n) WLAN PCIe Card
    Device ID: PCI\VEN_168C&DEV_002A&SUBSYS_0203168C&REV_01\4&149856BC&0&00E4
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
    Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_04381028&REV_06\3&11583659&0&FB
    Driver: n/a
    Name: Broadcom NetLink (TM) Gigabit Ethernet
    Device ID: PCI\VEN_14E4&DEV_1691&SUBSYS_04381028&REV_01\4&3699D3AB&0&00E5
    Driver: n/a
    Name: Intel(R) Management Engine Interface
    Device ID: PCI\VEN_8086&DEV_3B64&SUBSYS_04381028&REV_06\3&11583659&0&B0
    Driver: n/a
    Name: Intel(R) 5 Series/3400 Series Chipset Family 2 port Serial ATA Storage Controller - 3B26
    Device ID: PCI\VEN_8086&DEV_3B26&SUBSYS_04381028&REV_06\3&11583659&0&FD
    Driver: n/a
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    G2M Session Decoder,0x00600000,1,1,G2M.dll,4.08.0000.0723
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
    Expression Encoder Screen Codec 2,0x00600800,1,1,Microsoft.Expression.Encoder.EEScreen.Codec.dll,4.00.1639.0000
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
    WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
    Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
    WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
    WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
    WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
    WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8117.0416
    WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
    RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,12.00.0001.0647
    CyberLink Audio Spectrum Analyzer,0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
    CyberLink Audio Wizard,0x00600010,1,1,CLAudWizard.ax,1.00.0000.3616
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    CyberLink DVD Navigator,0x00200000,0,3,CLNavX.ax,8.00.0000.2808
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.4528
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17514
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
    File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
    CyberLink Audio Decoder,0x00600000,1,1,Claud.ax,6.03.0000.1322
    File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
    Expression Encoder Screen Codec 2,0x00600000,0,0,Microsoft.Expression.Encoder.EEScreen.Codec.dll,4.00.1639.0000
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17514
    CyberLink TimeStretch Filter,0x00200000,1,1,clauts.ax,1.00.0000.5423
    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17514
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    CyberLink Audio Effect,0x00200000,1,1,CLAudFx.ax,6.00.0000.5723
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
    RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,12.00.0001.0647
    CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,3.00.0001.2905
    Cyberlink SubTitle Importor,0x00200000,1,1,CLSubTitle.ax,1.00.0000.6016
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17514
    CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
    RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,12.00.0001.0647
    CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,8.04.0000.0205
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
    CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.9625
    Adaptive Streaming Filter,0x00600000,0,0,Microsoft.Expression.Encoder.Utilities2.dll,4.00.1639.0000
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
    Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17514
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
    Audio Capture Sources:
    Microphone (3- Logitech G35 Hea,0x00200000,0,0,qcap.dll,6.06.7601.17514
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
    WDM Streaming Capture Devices:
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    USB Audio Device,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
    WDM Streaming Rendering Devices:
    Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
