Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2010-06-25T18:46:32+00:00
    My sound only shuts off when after I wake my PC from sleep, and this has happened ever since I installed Windows 7 64 bit on my self built PC. A reboot always fixes the problem. I had XP 32 bit on here first. I've looked around for AGES trying to fix this, and it's really ____ me off now. I can usually solve anything myself, but this one is busting my bawlz. Seriously, I'm thinking about reformatting my entire computer (again...), do you think that would solve it? I am really tired of going through all this troubleshooting ____, I've tried it all and no avail. Reformatting would save me a lot of trouble, even though I have like 60 or 70 gigs of stuff I'd have to move 4gb at a time to my other PC.
    System Information
    Time of this report: 6/25/2010, 12:44:16
           Machine name: ROB-PC
       Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
               Language: English (Regional Setting: English)
    System Manufacturer: Gigabyte Technology Co., Ltd.
           System Model: GA-MA74GM-S2
                   BIOS: Award Modular BIOS v6.00PG
              Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.0GHz
                 Memory: 4096MB RAM
    Available OS Memory: 4094MB RAM
              Page File: 1378MB used, 6808MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7600.16385 64bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
            Sound Tab 1: No problems found.
            Sound Tab 2: No problems found.
              Input Tab: No problems found.
    Sound Devices
                Description: Speakers (Realtek High Definition Audio)
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_1458A002&REV_1002
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                Driver Name: RTKVHD64.sys
             Driver Version: 6.00.0001.6132 (English)
          Driver Attributes: Final Retail
                WHQL Logo'd: Yes
              Date and Size: 6/8/2010 17:21:02, 2394216 bytes
                Other Files:
            Driver Provider: Realtek Semiconductor Corp.
             HW Accel Level: Basic
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
                Description: Realtek Digital Output (Realtek High Definition Audio)
     Default Sound Playback: No
     Default Voice Playback: No
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                WHQL Logo'd: Yes
                Other Files:
                  Cap Flags: 0xF1F
                  HW Memory: 0
    Sound Capture Devices
    2010-09-16T02:28:33+00:00
    I have this exact same problem as well.  Just started happening over the last few months.
    I am using the M-Audio Audiophile 192 card in ASIO mode.
    It happens exactly as firegod describes.  If I put WMP on pause for an extended period of time, the sound does not come back on.
    Occasionally I can close all of the open programs and this brings the sound back.  Othertimes a complete reboot is the only fix.
    Now that I read firegod's reply is the first time I have noticed it's always after pausing WMP.
    Can someone else please try this test and see if WMP being paused causes your problem?
    Here is my DXDIAG just FYI:
    System Information
    Time of this report: 9/15/2010, 19:25:59
           Machine name: ROCK
       Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
    System Manufacturer: OEM
           System Model: OEM
                   BIOS: Phoenix - AwardBIOS v6.00PG
              Processor: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz (8 CPUs), ~2.7GHz
                 Memory: 12288MB RAM
    Available OS Memory: 12280MB RAM
              Page File: 2753MB used, 21803MB available
    DxDiag Notes
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Sound Devices
                Description: Line 1/2 (M-Audio Delta AP 192)
                Hardware ID: PCI\VEN_1412&DEV_1724&SUBSYS_36321412&REV_01
            Manufacturer ID: 239
                 Product ID: 65535
                       Type: WDM
                Driver Name: MAudioDelta.sys
             Driver Version: 5.10.0000.5074 (English)
                WHQL Logo'd: n/a
              Date and Size: 7/27/2009 13:44:48, 392712 bytes
                Other Files:
            Driver Provider: M-Audio
                  Cap Flags: 0x0
        Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
                  HW Memory: 0
                Description: S/PDIF (M-Audio Delta AP 192)
                 Product ID: 65535
                       Type: WDM
                WHQL Logo'd: n/a
                Other Files:
                  Cap Flags: 0x0
                  HW Memory: 0
                Description: Microphone (3- USB Audio Device)
      Default Sound Capture: Yes
      Default Voice Capture: Yes
                Driver Name: USBAUDIO.sys
             Driver Version: 6.01.7600.16385 (English)
              Date and Size: 7/13/2009 17:06:32, 109568 bytes
                  Cap Flags: 0x0
               Format Flags: 0x0
      Default Sound Capture: No
      Default Voice Capture: No
                  Cap Flags: 0x0
               Format Flags: 0x0
                  Cap Flags: 0x0
               Format Flags: 0x0
                Description: Microphone (HP Prem AF Webcam KQ245AA)
                  Cap Flags: 0x0
               Format Flags: 0x0
    System Devices
         Name: Intel(R) ICH10 Family PCI Express Root Port 4 - 3A46
    Device ID: PCI\VEN_8086&DEV_3A46&SUBSYS_3A468086&REV_00\3&2411E6FE&1&E3
       Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 18:45:45, 183872 bytes
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
    Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_3A368086&REV_00\3&2411E6FE&1&EA
       Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:27, 30720 bytes
       Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:31, 324608 bytes
       Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 17:07:09, 343040 bytes
         Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
    Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_12\3&2411E6FE&1&A0
       Driver: n/a
         Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_90\3&2411E6FE&1&F0
         Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
    Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_3A408086&REV_00\3&2411E6FE&1&E0
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
    Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_3A358086&REV_00\3&2411E6FE&1&E9
         Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
    Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_12\3&2411E6FE&1&A2
       Driver: n/a
         Name: Intel(R) PRO/1000 PT Desktop Adapter
    Device ID: PCI\VEN_8086&DEV_10B9&SUBSYS_10838086&REV_06\4&AC8666D&0&00E3
       Driver: C:\Windows\system32\DRIVERS\e1e6232e.sys, 9.13.0041.0000 (English), 3/26/2010 08:15:48, 287448 bytes
       Driver: C:\Windows\system32\e1e6232e.din, 4/23/2009 20:33:58, 2745 bytes
       Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/26/2009 17:05:46, 36472 bytes
       Driver: C:\Windows\system32\NicInE6.dll, 9.10.0039.0000 (English), 3/24/2010 08:11:20, 91840 bytes
       Driver: C:\Windows\system32\e1000msg.dll, 9.08.0000.0000 (English), 12/14/2007 21:06:06, 121440 bytes
         Name: High Definition Audio Controller
    Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_3A3E8086&REV_00\3&2411E6FE&1&D8
       Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:13, 122368 bytes
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
    Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_3A348086&REV_00\3&2411E6FE&1&E8
         Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
    Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_12\3&2411E6FE&1&A1
       Driver: n/a
         Name: M-Audio Delta AP 192
    Device ID: PCI\VEN_1412&DEV_1724&SUBSYS_36321412&REV_01\4&1EDC1F61&0&00F0
       Driver: C:\Windows\system32\DRIVERS\MAudioDelta.sys, 5.10.0000.5074 (English), 7/27/2009 13:44:48, 392712 bytes
       Driver: C:\Windows\system32\drivers\drmk.sys, 6.01.7600.16385 (English), 7/13/2009 18:01:25, 116224 bytes
       Driver: C:\Windows\system32\drivers\portcls.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:29, 230400 bytes
         Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
    Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_3A3C8086&REV_00\3&2411E6FE&1&D7
       Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 17:06:30, 51200 bytes
         Name: Intel(R) ICH10 Family SMBus Controller - 3A30
    Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_3A308086&REV_00\3&2411E6FE&1&FB
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 9 - 3410
    Device ID: PCI\VEN_8086&DEV_3410&SUBSYS_00008086&REV_12\3&2411E6FE&1&48
         Name: NVIDIA GeForce 9800 GT
    Device ID: PCI\VEN_10DE&DEV_0614&SUBSYS_C9753842&REV_A2\4&D57AD25&0&0018
       Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 189032 bytes
       Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/10/2010 05:38:00, 261268 bytes
       Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_a3da53f71c693e87\NvCplSetupInt.exe, 14.00.0000.0162 (English), 7/10/2010 05:38:00, 51549944 bytes
       Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 11240 bytes
       Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 13187176 bytes
       Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 7/10/2010 05:38:00, 65128 bytes
       Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 4/3/2010 22:55:32, 930272 bytes
       Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 2037864 bytes
       Driver: C:\Windows\system32\nvcompiler.dll, 6.14.0012.5896 (English), 7/10/2010 05:38:00, 14513768 bytes
       Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 6116968 bytes
       Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.5896 (English), 7/10/2010 05:38:00, 2761832 bytes
       Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 3089512 bytes
       Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 12471400 bytes
       Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 382568 bytes
       Driver: C:\Windows\system32\nvinfo.pb, 7/10/2010 05:38:00, 12264 bytes
       Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 19114088 bytes
       Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 7002216 bytes
       Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 7/10/2010 05:38:00, 56936 bytes
       Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 1625192 bytes
       Driver: C:\Windows\SysWow64\nvcompiler.dll, 6.14.0012.5896 (English), 7/10/2010 05:38:00, 10267240 bytes
       Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 4553832 bytes
       Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.5896 (English), 7/10/2010 05:38:00, 2506344 bytes
       Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 2892904 bytes
       Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 9818728 bytes
       Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 314984 bytes
       Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 14092904 bytes
       Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.5896 (English), 7/10/2010 05:38:00, 5107816 bytes
       Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 7/10/2010 05:38:00, 24011 bytes
       Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0062.0040 (English), 7/10/2010 05:38:00, 660072 bytes
       Driver: C:\Windows\system32\nvcod.dll, 1.09.0022.0107 (English), 7/10/2010 05:38:00, 260712 bytes
       Driver: C:\Windows\system32\nvcod1922.dll, 1.09.0022.0107 (English), 7/10/2010 05:38:00, 260712 bytes
         Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
    Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_3A3A8086&REV_00\3&2411E6FE&1&EF
         Name: Standard Dual Channel PCI IDE Controller
    Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_3A268086&REV_00\3&2411E6FE&1&FD
       Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 18:45:45, 12352 bytes
       Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 18:45:46, 48720 bytes
       Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 18:52:21, 24128 bytes
       Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 18:52:21, 155728 bytes
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
    Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_00008086&REV_12\3&2411E6FE&1&38
         Name: Texas Instruments 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_00000000&REV_00\4&1EDC1F61&0&18F0
       Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 17:07:13, 227840 bytes
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
    Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_3A398086&REV_00\3&2411E6FE&1&D2
    Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_3A208086&REV_00\3&2411E6FE&1&FA
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
    Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_00008086&REV_12\3&2411E6FE&1&18
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
    Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_3A388086&REV_00\3&2411E6FE&1&D1
         Name: Intel(R) ICH10R LPC Interface Controller - 3A16
    Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_3A168086&REV_00\3&2411E6FE&1&F8
       Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 18:48:27, 15424 bytes
         Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
    Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_00008086&REV_12\3&2411E6FE&1&08
         Name: Adaptec RAID 5805
    Device ID: PCI\VEN_9005&DEV_0285&SUBSYS_02B69005&REV_09\4&283A65AE&0&0048
       Driver: C:\Windows\system32\DRIVERS\arcsas.sys, 5.02.0000.17899 (English), 4/14/2010 17:09:00, 93784 bytes
         Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
    Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_3A378086&REV_00\3&2411E6FE&1&D0
         Name: Intel(R) 5520/5500/X58 I/O Hub Throttle Registers - 3438
    Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_12\3&2411E6FE&1&A3
       Driver: n/a
         Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3400
    Device ID: PCI\VEN_8086&DEV_3400&SUBSYS_100A3842&REV_12\3&2411E6FE&1&00
       Driver: n/a
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16590
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Line 21 Decoder,0x00600000,1,1,,
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
    File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    Overlay Mixer2,0x00200000,1,1,,
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
    Overlay Mixer,0x00200000,0,0,,
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
    Audio Capture Sources:
    Microphone (3- USB Audio Device,0x00200000,0,0,qcap.dll,6.06.7600.16385
    Line 1/2 (M-Audio Delta AP 192),0x00200000,0,0,qcap.dll,6.06.7600.16385
    Microphone (HP Prem AF Webcam K,0x00200000,0,0,qcap.dll,6.06.7600.16385
    S/PDIF (M-Audio Delta AP 192),0x00200000,0,0,qcap.dll,6.06.7600.16385
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16590
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
    Delta AP MIDI,0x00200000,1,0,quartz.dll,6.06.7600.16490
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
    WDM Streaming Capture Devices:
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    HP Prem AF Webcam KQ245AA,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
    USB Audio Device,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
    WDM Streaming Rendering Devices:
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    ,0x00000000,0,0,,
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16590
    Video Capture Sources:
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Line 1/2 (M-Audio Delta AP 192),0x00200000,1,0,quartz.dll,6.06.7600.16490
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
    DirectSound: Line 1/2 (M-Audio Delta AP 192),0x00200000,1,0,quartz.dll,6.06.7600.16490
    DirectSound: S/PDIF (M-Audio Delta AP 192),0x00200000,1,0,quartz.dll,6.06.7600.16490
    EVR Power Information
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
      Quality Flags: 2576
        Enabled:
        Force throttling
        Allow half deinterlace
        Allow scaling
        Decode Power Usage: 100
      Balanced Flags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force half deinterlace
        Force scaling
        Decode Power Usage: 50
      PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        Decode Power Usage: 0
    2010-11-11T08:17:32+00:00
    I have the same problem with audio disappearing after the computer idles for a few hours. I tried setting my Power Options to High Performance but the problem would still occur.
    Here is my computer spec (last updated 9/10/10):
    Intel Core 2 Quad 6600 (o/c to 3.00 GHz (9 x 333 MHz bus)) @ 1.275v and Thermalright Ultra-90 heatsink
    Asus P5W-DH Deluxe mobo (BIOS v2901)
    2x 2 GB Corsair RAM (TWIN2X4096-6400C5 G) @ 333 MHz (5-5-5-18) (Rated at 5-5-5-18 (CAS-TRCD-TRP-TRAS)) @ 1.9v
    PNY GeForce GTX 470 (driver: 258.96)
    Creative X-Fi Music (driver: 2.18.0015)
    1x Intel X25-M 80 GB SATA
    2x Seagate 1.5 TB SATA (one partition in RAID 0, rest in RAID 1 using Intel Matrix Storage Manager)
    1x Seagate 1 TB SATA (formatted 16 kbytes/sector)
    2x Pioneer DVD-711
    Corsair TX750W p/s
    DoubleSight DS-263N 26" monitor 1920x1200
    ViewSonic VA2431 monitor 1920x1080
    Windows 7 Pro 64-bit
    Logitech G25 (Gaming Software v5.09 64-bit)
    DXDiag:
    [code]
    System Information
    Time of this report: 11/11/2010, 00:14:12
    Machine name: COMP2
    Operating System: Windows 7 Professional 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
    System Manufacturer: ASUSTEK COMPUTER INC
    System Model: P5W DH Deluxe
    BIOS: BIOS Date: 06/17/09 20:04:53 Ver: 08.00.12
    Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~3.0GHz
    Memory: 4096MB RAM
    Available OS Memory: 4096MB RAM
    Page File: 2316MB used, 3824MB available
    DxDiag Notes
    Display Tab 2: No problems found.
    Display Devices
    Card name: NVIDIA GeForce GTX 470
    Manufacturer: NVIDIA
    Chip type: GeForce GTX 470
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_06CD&SUBSYS_079F10DE&REV_A3
    Display Memory: 3039 MB
    Dedicated Memory: 1248 MB
    Shared Memory: 1791 MB
    Current Mode: 1920 x 1200 (32 bit) (59Hz)
    Monitor Name: Generic PnP Monitor
    Monitor Model: DS-263N
    Monitor Id: CPL888D
    Native Mode: 1920 x 1200(p) (59.950Hz)
    Output Type: HDMI
    Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver File Version: 8.17.0012.6099 (English)
    Driver Version: 8.17.12.6099
    DDI Version: 10.1
    Driver Model: WDDM 1.1
    Driver Date/Size: 10/16/2010 10:55:00, 12788840 bytes
    WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
    Device Identifier: {D7B71E3E-458D-11CF-BD64-93271DC2C535}
    Vendor ID: 0x10DE
    Device ID: 0x06CD
    SubSys ID: 0x079F10DE
    Revision ID: 0x00A3
    Driver Strong Name: oem2.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section004:8.17.12.6099:pci\ven_10de&dev_06cd
    Rank Of Driver: 00E62001
    Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
    Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    D3D9 Overlay: Supported
    DXVA-HD: Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Current Mode: 1920 x 1080 (32 bit) (60Hz)
    Monitor Name: ViewSonic VA2431 Series
    Monitor Model: VA2431 Series
    Monitor Id: VSCD824
    Native Mode: 1920 x 1080(p) (60.000Hz)
    Output Type: DVI
    DDI Version: 10.1
    WHQL Logo'd: n/a
    Vendor ID: 0x10DE
    Device ID: 0x06CD
    Revision ID: 0x00A3
    DXVA-HD: Supported
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description: Speakers (Creative SB X-Fi)
    Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: ctaud2k.sys
    Driver Version: 6.00.0001.1375 (English)
    WHQL Logo'd: n/a
    Date and Size: 5/5/2010 20:30:10, 684376 bytes
    Other Files:
    Driver Provider: Creative
    Cap Flags: 0x0
    HW Memory: 0
    Description: SPDIF Out (Creative SB X-Fi)
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    WHQL Logo'd: n/a
    Other Files:
    Cap Flags: 0x0
    HW Memory: 0
    Description: Microphone (USB Audio Device)
    Date and Size: 7/13/2009 16:06:32, 109568 bytes
    Cap Flags: 0x0
    Format Flags: 0x0
    Description: Microphone (Creative SB X-Fi)
    Cap Flags: 0x0
    Format Flags: 0x0
    Description: Auxiliary (Creative SB X-Fi)
    Cap Flags: 0x0
    Format Flags: 0x0
    Description: Digital-In (Creative SB X-Fi)
    Cap Flags: 0x0
    Format Flags: 0x0
    Description: Line-In (Creative SB X-Fi)
    Cap Flags: 0x0
    Format Flags: 0x0
    Description: "What U Hear" (Creative SB X-Fi)
    Cap Flags: 0x0
    Format Flags: 0x0
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Device Name: Microsoft® Digital Media Pro Keyboard
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x045E, 0x00B0
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Device Name: G9 Laser Mouse
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC048
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Device Name: Logitech G25 Racing Wheel USB
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC299
    FF Driver: C:\Windows\system32\WmJoyFrc.dll
    FF Driver Date: 9/11/2009 11:48:26
    FF Driver Version: 5.08.0141.0000
    FF Driver Size: 328712 bytes
    Poll w/ Interrupt: No
    USB Devices
    • USB Root Hub
    | Vendor/Product ID: 0x8086, 0x27CB
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 7/13/2009 16:07:09, 343040 bytes
    | Driver: usbd.sys, 7/13/2009 16:06:23, 7936 bytes
    Gameport Devices
    PS/2 Devices
    • HID Keyboard Device
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    | Driver: kbdhid.sys, 7/13/2009 16:00:20, 33280 bytes
    | Driver: kbdclass.sys, 7/13/2009 17:48:04, 50768 bytes
    | Service: kbdhid
    | Service: kbdhid
    • Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: i8042prt.sys, 7/13/2009 15:19:57, 105472 bytes
    • Logitech HID-compliant G9 Laser Mouse
    | Matching Device ID: hid\vid_046d&pid_c048&mi_00
    | Upper Filters: LMouFilt
    | Lower Filters: LHidFilt
    | Service: mouhid
    | Driver: LHidFilt.Sys, 3/18/2010 01:00:00, 63568 bytes
    | Driver: LMouFilt.Sys, 3/18/2010 01:00:16, 57936 bytes
    | Driver: mouhid.sys, 7/13/2009 16:00:20, 31232 bytes
    | Driver: mouclass.sys, 7/13/2009 17:48:27, 49216 bytes
    | Driver: LkmdfCoInst.dll, 3/18/2010 01:00:08, 1843280 bytes
    | Driver: LMouFiltCoInst.dll, 4/28/2010 14:27:32, 53328 bytes
    • HID-compliant mouse
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    • Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 7/13/2009 17:45:55, 62544 bytes
    | Driver: sermouse.sys, 7/13/2009 16:00:20, 26624 bytes
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 32.3 GB
    Total Space: 76.3 GB
    File System: NTFS
    Model: INTEL SSDSA2M080G2GN ATA Device
    Drive: D:
    Free Space: 210.9 GB
    Total Space: 1277.2 GB
    File System: NTFS
    Model: RAID1
    Drive: F:
    Free Space: 525.8 GB
    Total Space: 953.9 GB
    File System: NTFS
    Model: ST31000333AS
    Drive: M:
    Free Space: 83.6 GB
    Total Space: 715.4 GB
    File System: NTFS
    Model: Maxtor OneTouch IEEE 1394 SBP2 Device
    Drive: X:
    Free Space: 150.0 GB
    Total Space: 307.2 GB
    File System: NTFS
    Model: RAID0
    Drive: R:
    Model: PIONEER DVD-RW DVR-111D ATA Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 15:19:54, 147456 bytes
    Drive: S:
    Drive: V:
    Model: GZGP QBS96Z41Y SCSI CdRom Device
    System Devices
    Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
    Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_81791043&REV_01\3&11583659&0&EF
    Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 16:06:30, 51200 bytes
    Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 16:06:31, 324608 bytes
    Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 16:07:09, 343040 bytes
    Name: Intel(R) 975X Memory Controller Hub - 277C
    Device ID: PCI\VEN_8086&DEV_277C&SUBSYS_81781043&REV_C0\3&11583659&0&00
    Driver: n/a
    Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_815B1043&REV_00\4&B244743&0&18F0
    Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 16:07:13, 227840 bytes
    Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
    Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_81791043&REV_01\3&11583659&0&EB
    Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 16:06:27, 30720 bytes
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_81791043&REV_E1\3&11583659&0&F0
    Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 17:45:45, 183872 bytes
    Name: Intel(R) 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E2
    Device ID: PCI\VEN_8086&DEV_27E2&SUBSYS_81791043&REV_01\3&11583659&0&E5
    Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
    Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_81791043&REV_01\3&11583659&0&EA
    Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_81E41043&REV_02\4&1A41C456&0&00E5
    Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 17:45:45, 12352 bytes
    Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 17:45:46, 48720 bytes
    Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 17:52:21, 24128 bytes
    Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 17:52:21, 155728 bytes
    Name: Intel(R) 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E0
    Device ID: PCI\VEN_8086&DEV_27E0&SUBSYS_81791043&REV_01\3&11583659&0&E4
    Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
    Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_81791043&REV_01\3&11583659&0&E9
    Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
    Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_81791043&REV_01\3&11583659&0&F9
    Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.01.7600.16385 (English), 7/13/2009 17:48:04, 16960 bytes
    Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
    Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_81791043&REV_01\3&11583659&0&E8
    Name: Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller
    Device ID: PCI\VEN_11AB&DEV_4362&SUBSYS_81421043&REV_20\4&AAA63F6&0&00E4
    Driver: n/a
    Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
    Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_81791043&REV_01\3&11583659&0&FB
    Driver: n/a
    Name: Intel(R) ICH7R/DH SATA RAID Controller
    Device ID: PCI\VEN_8086&DEV_27C3&SUBSYS_26041043&REV_01\3&11583659&0&FA
    Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 8.09.0000.1023 (English), 6/4/2009 17:54:36, 408600 bytes
    Name: Creative SB X-Fi
    Device ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00\4&B244743&0&10F0
    Driver: C:\Windows\system32\drivers\ctac32k.sys, 6.00.0001.1361 (English), 5/5/2010 20:30:02, 580696 bytes
    Driver: C:\Windows\system32\drivers\ctaud2k.sys, 6.00.0001.1375 (English), 5/5/2010 20:30:10, 684376 bytes
    Driver: C:\Windows\system32\drivers\ctoss2k.sys, 6.00.0001.1375 (English), 5/5/2010 20:30:18, 179288 bytes
    Driver: C:\Windows\system32\drivers\ctprxy2k.sys, 6.00.0001.1375 (English), 5/5/2010 20:30:26, 15960 bytes
    Driver: C:\Windows\system32\drivers\ctsfm2k.sys, 6.00.0001.1375 (English), 5/5/2010 20:30:34, 213080 bytes
    Driver: C:\Windows\system32\drivers\emupia2k.sys, 6.00.0001.1375 (English), 5/5/2010 20:30:42, 118360 bytes
    Driver: C:\Windows\system32\drivers\ha20x2k.sys, 6.00.0001.1375 (English), 5/5/2010 20:30:52, 1561688 bytes
    Driver: C:\Windows\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 5/5/2010 20:30:58, 16472 bytes
    Driver: C:\Windows\system32\drivers\CTEXFIFX.sys, 6.00.0001.1375 (English), 5/5/2010 20:29:52, 1417304 bytes
    Driver: C:\Windows\system32\drivers\CT20XUT.sys, 6.00.0001.1375 (English), 5/5/2010 20:29:34, 202840 bytes
    Driver: C:\Windows\system32\drivers\CTHWIUT.sys, 6.00.0001.1375 (English), 5/5/2010 20:29:42, 94808 bytes
    Driver: C:\Windows\system32\ctdlang.dat, 5/5/2010 18:46:30, 321512 bytes
    Driver: C:\Windows\system32\ctdnlstr.dat, 5/5/2010 18:46:30, 56509 bytes
    Driver: C:\Windows\system32\CtxfiRes.dll, 6.00.0001.1375 (English), 5/5/2010 18:56:46, 2560 bytes
    Driver: C:\Windows\system32\ctzapxx.ini, 5/5/2010 19:37:50, 54 bytes
    Driver
    2011-01-28T21:27:53+00:00
    I'm having the same problem as well and I'm at my wits end with this.  Audio randomly dies either from the computer being on for several hours, waking it from sleep mode, or muting/unmuting multiple times.  When the audio dies, any wmv I watch in Windows Media Player also plays in SLOW MOTION.  A reboot is the only thing that fixes this.  I'm running Windows 7 64 bit with an M-Audio Audiophile card with the latest drivers installed.  I really hope someone comes up with a solution for this soon because I feel like SMASHING MY COMPUTER every time this happens.
