Unable to Rip Audio CD using teh Media player, Windows 7 Ultimate.__Error Pop up : Windows Media Player cannot rip one or more tracks from the CD.
2009-10-24T18:16:09+00:00
I am runing the Windows 7 Ultimate
And is unable to rip any audio muice CD into the library.
The pop up error:
2010-09-17T05:08:50+00:00
This worked for me:
Open Windows Explorer -> right click music under libraries -> choose properties -> choose a valid folder for storing music... (mine was a network location)
2009-10-25T17:35:45+00:00
Hi James Tam,
Welcome to Microsoft Answers Community Forums!
Method 1:-
You might be able to complete the rip by turning on error correction.
> In Windows Media Player ->Click on Tools -> Options -> Devices, click the CD burner, choose> Advanced, and set the error correction to On.
Method 2:-
There are two ways to change rip settings while in the Player Library. You can insert a CD into your CD drive and click Rip settings, or you can click the Rip Music tab in the Options dialog box. The Rip Music tab in the Options dialog box offers additional options that aren't available on the Rip settings menu.
To rip music from a CD, do the following:
1.      For best results, make sure that you are connected to the Internet before you begin.
When your computer is connected to the Internet, the Player attempts to retrieve media information about the tracks being ripped from an online database. The Player then adds the information to the files during ripping.
Note that you can rip a CD when your computer isn't connected to the Internet. However, the Player won't be able to identify the name of the CD, the artist who created it, or the names of the songs until you go online.
2.      Insert an audio CD into the CD drive.
3.      (Optional) If you want to select a different format (for example, MP3 instead of WMA) or bit rate (for example, 192 Kbps instead of 128 Kbps) for the files created during ripping, in the Player Library, click the Rip settings menu, and then click Format or Audio Quality.
4.      (Optional) If you don't want to rip every song, in the Player Library, clear the check boxes next to the songs you don't want to rip.
5.      Click the Rip CD button in Now Playing mode or Rip CD in the Player Library to begin ripping.
1.      For more information visit the following link:-
http://windows.microsoft.com/en-us/windows7/Change-settings-for-ripping-music
 Let me know if this helped.
Regards,
Divya R – Microsoft Support.
79 additional answers
    2012-01-14T18:01:11+00:00
    I tried everything here's what i done
    Reinstalling.
    Changing discs.
    It won't let me change the format it just says 'the settings for ripping music could not be applied' and i cant change where i store my music i tried clicking on it but wont help. This must of all happened when i installed songbird its a media player for my Gogear muse but it was **** so i decided to take it off and when i did i wen't to go listen on windows media player 11 or 12 (cant remember) anyway when i click to play a music it just skipped it and there was a red circle with a white cross in it and all the songs name were edited and placed in the wrong ablum and i couldn't play some musics i tried deleting all of my music in the libary and import them again but nothing so i tried ripping the music again but wont let me, so thats how it all happen. Please help i really dont want to switch to another media player just want this one.
    2012-01-20T09:59:09+00:00
    2012-01-20T16:19:51+00:00
    WOW!... the answer was to simply go to IE, right click on music folder; choose properties, then click the restore defaults button. I had had no problem until I attempted to switch to mp3 format  rather than wma for ripping output...
    absolutely never would have guessed the solution would be found in IE rather than Media Player!
    You Rock! If only I would have come here FIRST rather than wasting hours of research re: codecs & yada yada
    Cid the grateful!
