Speakers' Echo Effect - how to turn off?
2009-03-07T17:05:57+00:00
There is an "echo" effect to all audio (music, game sounds, people speaking), which garbles sounds and is annoying...is there anyway fix this? I have a new motherboard (Gigabyte EP45-DS3L) and am running Vista. I have Bose Companion 2 speakers (just right & left, not surround). I've opened up the Volume Mixer and looked at the speaker info under Control Panel/Sounds. I've also tried Windows Help, but as I have no computer savvy whatsoever, I'm stumped. Thanks in advance for your guidance!
2009-03-13T00:59:17+00:00
Hello ratsees and welcome to the Microsoft Answers forum.
Some things to check for…
You will first want to ensure that this “echo” effect is not being caused by a third party application. The easiest method would be to test the default Windows sounds, then try configuring the speakers, and if the issue persist to try Safe Mode - to eliminate third party software or services as the cause.
Use the default Windows Sounds
1.    <br>Click<br>Start, click Control Panel, click Hardware and Sound, and then click<br>Sound.<br><br><br>2.    <br>In the<br>Sound window click on the Sounds (tab).<br><br><br>3.    <br>You will see a box with a list of items one being<br>Asterisk.<br><br><br>4.    <br>Click on<br>Asterisk, or any item in that box, and then click Test.<br><br><br>5.    <br>You should hear audio coming from your system.<br><br><br>6.    <br>If the clip was not long enough select another item, and then click<br>Test.<br><br><br>7.    <br>Determine whether or not the distorted audio is present.
Configure the speakers
1.    <br>Click<br>Start, click Control Panel, click Hardware and Sound, and then click<br>Sound.<br><br><br>2.    <br>In the<br>Sound window right-click your Speakers and select Configure Speakers.<br><br><br>3.    <br>Follow the on-screen setup, and<br>Test the available configurations.<br><br><br>4.    <br>Indentify whether or not one configuration appears to have less of an “echo” than others.<br><br><br>5.    <br>If the issue is resolved by modifying the configuration then you do not need to do anything further.
Boot into Safe Mode
This is done to determine if possible software that came with the speakers or if third party software may be causing this unexpected behavior. If the issue does not persist in Safe Mode then the cause is most likely a third party application, driver, or service.
Regardless please let us know how the troubleshooting works for you, and the results of each step.
1.    <br>Restart your computer if it is powered on.<br><br><br>2.    <br>Tap the<br>F8 key after your computer initially powers on.<br><br><br>3.    <br>Once you see the<br>Advanced Boot Options menu you can stop tapping.<br><br><br>4.    <br>Use the up/down arrow keys to highlight your selection.<br><br><br>5.    <br>Select<br>Safe Mode and press Enter.<br><br><br>6.    <br>You should see drivers loading, and then<br>Please wait.<br><br><br>7.    <br>You should then be at the<br>Welcome Screen.<br><br><br>8.    <br>Logon to your computer using an account with Administrator privileges.
[Jared
Microsoft Answers Support Engineer Posting to you from Windows 7!
52 additional answers
    2011-04-22T15:13:21+00:00
    Thanks so much ! What an easy fix
    2011-03-26T21:39:35+00:00
    same here, mine was set on stone coridor, very annoying. thanks
    2010-12-01T23:56:32+00:00
    Thanks ratsees,
    I had the same problem as you, I followed your solution and it worked great! Thanks again.
    nugget49er
    2009-05-03T13:45:38+00:00
    Problem finally solved!
    The main problem here was my inexperience with Vista. I finally went to:
    Control Panel
    Realtek Hd Audio Manager
    clicked on Sound Effects tab
    dropped down the "environments" list.
    I chose "padded cell" (grin) and Voila! no more echo.
    Thank you so much! These forums are the best!
    /Ratsees
