My battery is set up to charge to 80%. How to I change it to charge a 100%?
2010-01-31T15:47:12+00:00
I have a laptop samsung Q320
Thanks!
2010-03-13T05:58:33+00:00
Click "Start" > All programs > Samsung > Battery Life Extender > Battery Life Extender .  Click "yes" if prompted. When the program launches you should have the option to go back and forth between 100 and 80% on your battery.
Hope this is what you were looking for.
2010-02-01T04:55:34+00:00
Hi MEY85,
Since you need support for the Samsung Laptop battery to setup a charge of 100%, you may need to get in touch with Samsung for further assistance.
You may refer the following link to contact Samsung:
http://www.samsung.com/us/info/contactus.html#
Praseetha K
45 additional answers
    2012-07-02T18:57:23+00:00
    While this would have worked like a charm, after bringing my computer back to the store where it was purchased, they had done a format/reinstall of my OS... they failed to put back the samsung Battery Life Extender program.... after finding this post I went to get the program and like magic... I was then able to change that stupid setting for the battery. THANK YOU SOO MUCH !!!!!! <3
    2012-04-07T03:13:30+00:00
    Cheers mate, works a craker!!
    2011-12-20T18:24:59+00:00
    Fantastic. Thanks very much. I didnt realise it was so simple.
