My battery is set up to charge to 80%. How to I change it to charge a 100%?
2010-01-31T15:47:12+00:00
I have a laptop samsung Q320
Thanks!
2010-03-13T05:58:33+00:00
Click "Start" > All programs > Samsung > Battery Life Extender > Battery Life Extender .  Click "yes" if prompted. When the program launches you should have the option to go back and forth between 100 and 80% on your battery.
Hope this is what you were looking for.
2010-02-01T04:55:34+00:00
Hi MEY85,
Since you need support for the Samsung Laptop battery to setup a charge of 100%, you may need to get in touch with Samsung for further assistance.
You may refer the following link to contact Samsung:
http://www.samsung.com/us/info/contactus.html#
Praseetha K
45 additional answers
    2011-05-01T06:35:35+00:00
    Hello every one,
    I have the same problem, I have set the battery to charge to 80%, and then I have changed the OS from Vista to Windows7; therefore, now I can't find the Samsung file.
    What can I do??
    Noora
    2011-04-22T18:15:13+00:00
    thanks much
    2011-04-16T21:48:50+00:00
    I echo Michelle76542, this was very helpful. I read a tip on how to change it 80% some time ago, and then forgot how to change it back! Battery is on its way back to 100% :-)
