How to turn on Sony Vaio built in Webcam on Windows 7
2010-08-20T20:56:05+00:00
Original Title: webcam help
hi please can someone help as i can't figure out how to switch on the inbuilt webcam on my sony viao i'm on windows 7 !!!!!
2010-08-21T18:02:19+00:00
Hi Sarah,
Steps to turn on integrated WebCam on Sony Vaio Laptop
a.    Click on Start and then click on All programs.
b.    Go all the way to the bottom until you see “Arcsoft Webcam companion”
c.    Click on it and then click on Webcam companion 3 to turn your webcam.
That’s it.
Seeing is believing
http://windows.microsoft.com/en-US/windows7/Seeing-is-believing-Use-a-webcam-to-bring-your-instant-messaging-to-life
Hope this information is helpful and let me know if you need any further assistance.
Mouneshwar R – Microsoft Support
Visit ourMicrosoft Answers Feedback Forum and let us know what you think
[If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.]
74 additional answers
    2012-02-22T16:36:09+00:00
    Hi i am facing the same issue as i have HP 6530b LT with Win7 installed the inbuilt webcam is installed but not able to use the it can any one help me
    2012-02-25T23:37:27+00:00
    hi that link as been expired could u provide another ...been trying to solve this issue for months!
    2012-02-26T01:10:20+00:00
    Follow the procedure below to resolve the issue:
    1. Click the Start button, and then click Control Panel .
    2. In the Control Panel window, click System and Maintenance .
    3. In the System and Maintenance window, click Device Manager . NOTE: If prompted for an administrator password or a User Account Control prompt is displayed, type the appropriate password or click Continue .
    4. In the Device Manager window, click the plus (+ ) next to Imaging devices to expand the selection. NOTE: If Imaging devices is not listed, click to select a different category such as Computer and then proceed with Method 1 below.
    5. Depending on the state of the Sony Visual Communication Camera device listed under Imaging devices , perform one of the following procedures.
      • Method 1 : If Sony Visual Communication Camera is missing, follow the procedure below to resolve the issue:
        1. On the menu bar, click Action .
        2. Click to select Scan for hardware changes . NOTES:
          • Scan for hardware changes will automatically detect the camera hardware and install the necessary driver.Sony Visual Communication Camera will then show as properly installed, meaning that the device does not have a yellow exclamation point or question mark. NOTE: The camera should now function properly and after restarting the ArcSoft WebCam Companion software the error should not be displayed.
          • If Sony Visual Communication Camera is displayed with a yellow explanation point or question mark, follow the procedure in Method 3 .
          • If Sony Visual Communication Camera still does not appear, service will be required.
      • Method 2 : If Sony Visual Communication Camera is disabled, follow the procedure below to enable it:
        1. Click to select Sony Visual Communication Camera .
        2. On the menu bar, click Action and then click Enable . NOTE: The camera should now function properly and after restarting the ArcSoft WebCam Companion software the error should not be displayed.
      • Method 3 : If Sony Visual Communication Camera is displayed with a yellow explanation point or question mark, follow the procedure below:
        2. On the menu bar, click Action , and then click Uninstall .
        3. In the Confirm Device Uninstall window, click the OK button.
        4. In the Device Manager window, on the menu bar, click Action and then click to select Scan for hardware changes .
        5. After the scan is complete, on the menu bar, click Action and then click to select Update Driver Software .
        6. In the Update Driver Software window, you will be prompted to manually or automatically install the driver. Select Search automatically for updated driver software and then follow the on-screen instructions. NOTE: The camera should now function properly and after restarting the ArcSoft WebCam Companion software the error should not be displayed.
    2012-02-28T23:52:50+00:00
    Thanks ...but my sony visual communication camera still didnt appear after scanning in device manager settings and imaging devices tab wasnt there wud it be under a different name?......what kind of service would i need now?
