No sound via HDMI output when connecting laptop to TV
2010-08-07T09:52:34+00:00
Original title: HDMI Laptop to TV - No Sound
Up until a few weeks ago it worked well:  I simply connected the HDMI cable between my laptop and TV and got both the audio and video on the TV (After selecting the right AV channel on the TV).  Now I only get the video.
I have looked through other questions on this forum but have not found anything that works.  I am reluctant to change too much, as it worked before.
In my "Playback Devices" I see two devices: "Speakers" (Default) and "SPDIF Interface".
Laptop: Packard Bell Easy Note TJ65 Pentium Dual-Core CPU
Windows 7 Version 6.1 (Build 7600)
TV: Panasonic Plasma TX-PS42S10B (HD Ready)
Any ideas, anybody?  I feel that as I have made very few changes, the fix must be simple.  I haven't tried a different cable yet, but I'm pretty sure it's OK.
2010-08-15T00:01:17+00:00
BINGO!!
(So I had to go on to JustAnswers.com & pay £28, but I got the answer straight away ... wish I had gone earlier!)
Happy to share, though, for anyone struggling with this annoying problem...
I went on to Device Manager (Start Button > right click on Computer and selectManage) and uninstalled the device calledIntel(R) High Definition Audio HDMI.  Restarted the computer.  Connected TV with HDMI cable.  Right clicked on the little speaker symbol & slected Playback Devices.  Panasonic TV shows as a device.  Right clicked on it & set as default.  I got my sound back & everything works fine.
It seems the driver had been updated somewhere along the line and was no longer compatible.  Following this process makes the computer put back its own driver.  All this time I was looking for a newer driver, and what it wanted was the old one!
For the record, the device in Device Manager is now called High Definition Audio Device. No mention of HDMI!
By the way, if you right click on the desktop you get a wizard to set up the TV interface.
63 additional answers
    2010-08-09T19:58:11+00:00
    Carlos,
    The problem is that I only see two devices: "Speakers" (Default) and "SPDIF Interface".
    I guess if you have XP you might not be able to walk me any further!  Thanks for your support anyway.
    Kevin
    Don't you have a "Show hidden devices" option somewhere?
    It might be hidden and disable.
    This is as far as I can get.
    Carlos
    2010-08-10T17:39:44+00:00
    I have  Show Disabled Device and Show Disconnected Device as per Gokul's reply above, but noShow Hidden devices.
    I guess I will have to sit tight & see if someone comes along who might know the answer!
    2010-08-11T01:03:47+00:00
    Gerbil,
    Last shot, found no more in my bag o'tricks.
    Is there any chance that the HDMI audio device (if it ever existed!) is disabled in BIOS?
    That might explain everything.
    Carlos
    2010-08-13T00:03:09+00:00
    Well, after a fair amount of research, it seems that the most common solution to this problem is to install the latest graphic driver from the Intel site.
    However, I ran the Intel driver update utility, and it reported that I had a customised graphics driver for the chipset, and that the Intel generic driver might cause the computer to malfunction.  So I downloded the driver off Packard Bell site but it still doesn’t work.
    Still looking…..
