No sound via HDMI output when connecting laptop to TV
2010-08-07T09:52:34+00:00
Original title: HDMI Laptop to TV - No Sound
Up until a few weeks ago it worked well:  I simply connected the HDMI cable between my laptop and TV and got both the audio and video on the TV (After selecting the right AV channel on the TV).  Now I only get the video.
I have looked through other questions on this forum but have not found anything that works.  I am reluctant to change too much, as it worked before.
In my "Playback Devices" I see two devices: "Speakers" (Default) and "SPDIF Interface".
Laptop: Packard Bell Easy Note TJ65 Pentium Dual-Core CPU
Windows 7 Version 6.1 (Build 7600)
TV: Panasonic Plasma TX-PS42S10B (HD Ready)
Any ideas, anybody?  I feel that as I have made very few changes, the fix must be simple.  I haven't tried a different cable yet, but I'm pretty sure it's OK.
2010-08-15T00:01:17+00:00
BINGO!!
(So I had to go on to JustAnswers.com & pay £28, but I got the answer straight away ... wish I had gone earlier!)
Happy to share, though, for anyone struggling with this annoying problem...
I went on to Device Manager (Start Button > right click on Computer and selectManage) and uninstalled the device calledIntel(R) High Definition Audio HDMI.  Restarted the computer.  Connected TV with HDMI cable.  Right clicked on the little speaker symbol & slected Playback Devices.  Panasonic TV shows as a device.  Right clicked on it & set as default.  I got my sound back & everything works fine.
It seems the driver had been updated somewhere along the line and was no longer compatible.  Following this process makes the computer put back its own driver.  All this time I was looking for a newer driver, and what it wanted was the old one!
For the record, the device in Device Manager is now called High Definition Audio Device. No mention of HDMI!
By the way, if you right click on the desktop you get a wizard to set up the TV interface.
63 additional answers
    2013-05-30T09:07:05+00:00
    Whatever, it works now. thanks
    2013-09-30T18:00:03+00:00
    Method 3 (which worked for me!)
    1. Download 'Realtek Audio Manager,' or other HD sound management driver/software compatible with your PC.
    2. Follow method 1 described by 'Gokul - Microsoft Support'
    Like everyone else I initially had sound and video when projecting to a second screen and then all of a sudden BAM!! Gone!! no matter what I did the windows sound manager couldn't detect a HD audio device (Video was fine?!).
    Somewhere along the way the drivers for transferring the audio signal went walkies and installing a HD audio manger fixed the problem for me.
    Also - for whatever reason Gerbil's solution did'n't work for me but looks like it has worked for others.
    2013-10-06T10:24:30+00:00
    Went through all 5 pages of this thread, tried all ideas, but nothing seems to work for me.
    When I go through Sound/Playbeck settings it's all there as it should be: Digital Audio (HDMI) is displayed and set as a default device. While playing a video, green bars keep jumping indicating there is a sound...somewhere, but not on my TV. Just a video.
    In Device Manager there is no black arrow. Everything is in order.
    But still no sound on TV. Just video.
    Tried reinstalling High Definition Audio Controller. Not helping.
    The laptop manual (Acer TravelMate 5730, and the TV is LG 37LH2000) has a single sentece on this: it supports HDMI !!!. My other two laptops (both Dell) are connecting perfectly to the same TV with the same cable though. At least I know it's something with Acer.
    I simply can't seem to get around this one.
    I have exactly the same problem. Did you find a fix?
    Thank you.
    2014-12-14T16:28:42+00:00
    AWESOME this worked perfectly. Thank you. Beats hell outta paying Microsoft to fix it remotely. Ive got my sound. Its movie time. Thanks again.
