Other issues or features related to Microsoft Edge on Windows 11
Good day,
Sometimes when I am using MS Edge, the window display blurs seemingly without cause and stays there for a few minutes. When I say "window display" I mean it only applies to the Edge Work window I have open (I don't remember it occurring with other profile windows), and it isn't the whole window, but only the page display which is everything below the URL line.
At first, I suspected this might have something to do with Sleeping Tabs since it sometimes occurs when I step away from my computer. When I return, if I click anywhere on the page display, it returns to normal. However, I tried disabling sleeping tabs when it occurred randomly (while I was using the page) and it still persisted.
Apart from when I have left the computer for a while and clicking, there is nothing that I have found that consistently restores the normal unblurred screen. I have had some level of success with opening new tabs (this sometimes fixes it), but this does not always work and is not predictable.
Below are two screenshots - normal and blurred:
My current version of Edge is 118.0.2060.1 (Official build) dev (64-bit). I have also reported this through Send Feedback.
If anyone knows about this, I would appreciate any assistance.
Thank you.
119.0.2151.42 (Beta) and 120.0.2186.0 (Dev/Canary) should have the fixes.
I'll reply back with the Edge versions that have the change that allows "no policies" to imply "never blur for inactivity". The change that I previously mentioned that is in Edge Canary is going to require a second fix (due to technical reasons). Hopefully that will land in Canary within 1-2 days; and then both fixes will be taken together to Beta/Stable.
Hi, was having the same issue too, then I found this in Settings - System and performance - Optimize Performance - Fade sleeping tabs.
Could this be the cause? It was enabled when I found it, just turned it off, will see if it helps.
Another one I just disabled was "Try the new look" in Appearance. Realised it started happening after Edge had the new rounded edges look. Wasn't having this before the appearance update. Will see how it goes.
@nicky ly thank you!
I didn't think to look for the keyword "fade" in the menus, I was looking for "blur".
I have toggled it and gave feedback using the thumbs-down icon just above. Now that I'm searching for the right keyword, the right config option was immediately obvious.
edit: sadly, the setting didn't change the fade-out/blur behaviour as expected
legend.
Have this as well. On version 117.0.2045.31. It happens when I open a link using mouse wheel to open in a new tab, but not always. Started happening after an update.
