Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
I turning off all the settings was an instant fix, however weirdly turning the settings back on did not bring back the issue. Thank you Larry Rich1 for fix
Thanks Larry,
I think in my case it was the "graphics acceleration" causing the problem.
Stan
This also fixed it for me
Please ignore this person. Toggling a single setting from off to on is exactly how you resolve this problem and it definitely doesn't create new problems. However, following this person's advice creates the problem of losing your browser data.
Mine is working after this:
Hope this can help you.
For others,
I made the changes Larry suggested, but Edge would not close. I reselected the items I had turned off, and Edge now closes.
Jon
I.T. Illiterate
