Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Thank you! Just encountered this problem and this worked!
This fully worked for me and was extremely easy to follow. Thanks!
Larry,
This worked perfectly! Thank you so much for sharing your knowledge.
I had the same issue, I saw the original post this morning and ran some tests before posting. This seems to be working for me:
1 Click three dots at top right
2 Click settings
3 Click System and performance
4 Click System
Turn off the following:
I have not determined which is the issue but turning each back on one at a time and testing can be done by you. But this did work for me.
Larry
IT Professional
Use chrome ✅
I noticed this yesterday morning too! This has got to be something with Microsoft. Any real answer here for a long term solution?
