Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Wow. After changing those settings, I was able to immediately close Edge. Thank you for the advice. MS is so clunky.
Thank you. How annoying! I
I also have the same issue, and I am using an MSI notebook on Windows 11 Pro. It has been going on for about a week now. I, too, can only close by task manager. Now, if I open two windows, the second will close by the red X, but the first window does not.
Ask yourself why this started happening. My Win11 was working fine until the recent up. By going thru all the steps you posted is temp fix, not a solution of the underlying cause.
The only one i had on was graphics acceleration and after turning it off and restarting browser, all works fine now
