Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-17T15:54:22+00:00
    I had the same issue, I saw the original post this morning and ran some tests before posting. This seems to be working for me:
    1 Click three dots at top right
    2 Click settings
    3 Click System and performance
    4 Click System
    Turn off the following:
    I have not determined which is the issue but turning each back on one at a time and testing can be done by you. But this did work for me.
    Larry
    IT Professional
    2025-05-17T15:37:19+00:00
    Dealing with the same issue. Task manager is the only way I've found to close out of edge, I believe this just started happening today, so maybe something related to a recent update? Hopefully this issue is fixed soon. Otherwise I'm switching to a different browser.
    2025-05-17T15:29:52+00:00
    I am experiencing the exact same problem. Thanks for raising this; I tried the modify option and no solution.
    2025-05-17T15:10:29+00:00
    HI Virginia
    I have run the commands you suggest, deleted browsing history and reset Edge but the problem returns after a few minutes.
    I can't get it it to occur (yet) in Private Mode.
    I was asked about this by a friend this morning and now this afternoon, Edge on my PC has started locking up as well,
    It doe not close when I right click on the taskbar icon and select Close Window but I can lslose it down with Task Manager.
    My money would be a bug in this months Windows Update.
    Stan
    2025-05-17T16:09:36+00:00
    Thanks Larry,
    I think in my case it was the "graphics acceleration" causing the problem.
    Stan
    2 Click settings
    4 Click System
    Larry
    IT Professional
