Other issues or features related to Microsoft Edge on Windows 11
As the title says, I was wondering why Edge is running in the background after Windows Update installed and I disabled Copilot from the taskbar. Edge's settings right now are like this:
Sidebar: disabled
Show Bing chat on sidebar: disabled
Startup Boos: disabled
Continue running background extensions and apps when Microsoft Edge is closed: disabled
And now I found this running in the background with the browser closed:
That's not even the browser's updater service. I stopped the task and it opened itself again a few minutes later.
As if the fake widgets I don't like or use are always running in the background despite many things I've tried, now I have Edge using system resources for no apparent reason.
Please help me find a solution to this problem.
You're welcome. I'm glad to help
it did the trick.
thank you
So the bug is that edge does not close when you dismiss the copilot, that is all they need to resolve.
Not exactly. The current Edge misbehavior on Windows 11 (Edge always running in the background once closed, regardless of related settings to not do it) occurs even when you turn Startup boost and background extensions and apps Edge System settings off AND disable Copilot both on Windows and turn it off via Edge's Sidebar settings.
As of now, the only effective unofficial workaround that resolves this issue is as follows:
