Other issues or features related to Microsoft Edge on Windows 11
As the title says, I was wondering why Edge is running in the background after Windows Update installed and I disabled Copilot from the taskbar. Edge's settings right now are like this:
Sidebar: disabled
Show Bing chat on sidebar: disabled
Startup Boos: disabled
Continue running background extensions and apps when Microsoft Edge is closed: disabled
And now I found this running in the background with the browser closed:
That's not even the browser's updater service. I stopped the task and it opened itself again a few minutes later.
As if the fake widgets I don't like or use are always running in the background despite many things I've tried, now I have Edge using system resources for no apparent reason.
Please help me find a solution to this problem.
Having the exact same issue.
no settings can fix this
I confess that the only reason I knew that Edge was still running in the background is because I use CCleaner regularly and it started "skipping" cleaning Edge. When I would bring up Task Manager, iterations of Edge would actually INCREASE even though Edge was closed. I tried every "solution" I could find to fix this until I found a solution to disable and remove Co-Pilot with a registry hack here: https://www.elevenforum.com/t/completely-disable-and-remove-copilot-in-windows-11.23264/. If you don't use this intrusive, invasive, annoying gizmo forced upon us by MS, try this hack. Cheers!
Sadly, it made no difference. I have disabled all the things that can possibly keep Edge open, and even disabled it in the startup part in Task Manager, which to my surprise wanted to open like 47 instances, but no, it still remains open after you close Edge, and also reopens itself sometime later.
I'm starting to believe this behavior is not only related to copilot, but the widgets as well since (I think) they use Edgeview to work.
Yes, widgets are also part of the problem.
And it's still not fixed. Here is another thread reporting the same issue:
