Other issues or features related to Microsoft Edge on Windows 11
As the title says, I was wondering why Edge is running in the background after Windows Update installed and I disabled Copilot from the taskbar. Edge's settings right now are like this:
Sidebar: disabled
Show Bing chat on sidebar: disabled
Startup Boos: disabled
Continue running background extensions and apps when Microsoft Edge is closed: disabled
And now I found this running in the background with the browser closed:
That's not even the browser's updater service. I stopped the task and it opened itself again a few minutes later.
As if the fake widgets I don't like or use are always running in the background despite many things I've tried, now I have Edge using system resources for no apparent reason.
Please help me find a solution to this problem.
The answer is simple: no. And that's the problem.
Another thread on Reddit asking why and reporting the same issue:
Please fix this mess. It's very annoying and unacceptable behavior.
Someone created a recent discussion thread on the r/MicrosoftEdge subreddit reporting the same bug:
https://www.reddit.com/r/MicrosoftEdge/comments/17hnscf/edge_keeps_running_in_the_background/
Please, we need updates from Microsoft on the issue, and a fix is required ASAP.
Hi, I ran Windows Update with even the optional updates, but Edge is still running in the background after it's been closed for a couple of hours.
Either a previous update broke Edge's options to not run in the background, or something is depending on it to run and keeps it open, but so far all I can do is end the task in task manager and hope it won't open itself again sometime later.
I see the same issue. With Build 22621.2361.
