Other issues or features related to Microsoft Edge on Windows 11
In Edge Collections, how do I sort collections alphabetically? It used to be easy to do.
yes that use to be true until something was changed and this option is no longer present
I reported the problem to the Edge developers, as you suggested.
Thanks for your help!
Your version is fully up to date, there must be a bug in your Edge, because that is the version I am also running, it would be best to report this missing functionality to the Edge Developers by pressing Alt + Shift + i in Edge.
113.0.1774.50 )Official build) (64 bit)
Says I'm up to date.
