Bing safesearch stuck at "strict" on Edge
2022-02-16T09:34:31+00:00
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Bing | Safety and privacy | Adult content and SafeSearch
    2023-10-28T09:44:27+00:00
    still stuck for me
    2022-10-01T15:56:24+00:00
    I am in the UK and have Windows 10 Professional suddenly it changed about 2 weeks ago and like everyone else I cannot change it.
    I get ''our current Bing SafeSearch setting filters out results that might return adult content. '' It is even blocking out some very safe sites so what have Microsoft done at 80 I take exception to Microsoft changing something that I do not want.
    2022-10-01T14:19:28+00:00
    i have tried all suggestions to cancel safesearch without success!!
    any ideas??
    david shaw
    2022-08-16T19:25:38+00:00
    Since I use varying versions of Edge on my MacBook, Windows, and Android, it eventually will reset the safe search and I am always re-unchecking it.
    2022-08-01T12:43:19+00:00
    Maybe due by the fact you are using Kids mode / Family features.
