Bing safesearch stuck at "strict" on Edge
2022-02-16T09:34:31+00:00
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Bing | Safety and privacy | Adult content and SafeSearch
    2023-02-10T00:20:08+00:00
    Same problem, I think for a lot of cases it's caused by Windows Educational Edition
  2. Deleted
    2022-06-01T13:56:25+00:00
    Same problem. Registry hack didn't work; private window didn't work. Switched to Duck etc and that was ok until Windows update. Bing still would not search.
    2022-08-01T12:40:33+00:00
    Windows 10 configuration recommendations for education customers | Microsoft Docs
    Area How to configure What this area does Windows 10 Education Windows 10 Pro Education Windows 10 S
    Safe search SetEduPolicies Locks Bing safe search to Strict in Microsoft Edge This feature is already set This feature is already set The policy must be set
    SetEduPolicies
    SetEduPolicies is a policy that applies a set of configuration behaviors to Windows. It's a policy node in the SharedPC configuration service provider.
    Use one of these methods to set this policy.
    2022-07-30T08:45:48+00:00
    Great! So much for using edge. I've never used safe searching 35 years. Never turn safe search on in any browser. Have no idea why this is even activated in edge. Only in Windows.
