Bing safesearch stuck at "strict" on Edge
2022-02-16T09:34:31+00:00
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Bing | Safety and privacy | Adult content and SafeSearch
  1. Deleted
    2023-09-13T20:12:37+00:00
    I fixed my issue by witching to a Windows 11 Pro License key I got in a sale for $33. It was Education Edition causing the problem for sure.
    2023-09-13T19:24:53+00:00
    Mine has been like this for years - must be something with having access to office via school or something but i think all of those are quite old now... no one has ever had a solution
    2023-08-21T11:30:38+00:00
    Many thanks.
    2023-08-20T11:07:40+00:00
    It doesn't work. I tried the method you provide but the SafeSearch still stuck as Strict.
    Loay Apo Mahmood suggested that you search with google, not Bing. You should be
    able to turn off SafeSearch with google.
    https://www.google.com/safesearch
    Don
    Thank you Don. When I visit www.google.com/safesearch, it shows I have no right to adjust the setting. it needs me to verify something. Then I click the more information below, it shows a verification things, which need I to fill in the name, date of birth and phone number. The fact is I am Chinese and take a long vacation in South Korea, so I do not have local phone number, so could you please give me more hands, thanks in advance.
    Regards,
