Bing safesearch stuck at "strict" on Edge
2022-02-16T09:34:31+00:00
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Bing | Safety and privacy | Adult content and SafeSearch
    2023-11-15T12:06:03+00:00
    i cant change any of that and it wont let me and when i change the safe search module in settings it keeps resetting to moderate when i switched it off amd signed out and back in on different computers and also i cant change it on microsoft edge, google, chrome and in bing in the classroom programme
    2023-11-02T17:05:04+00:00
    Hello my friend, first it's a pleasure to be able to help you today.
    My name is Vinicius.
    I am an independent advisor on the Microsoft Community platform.
    Hey AlanThuy, how are you today? Hope you're well.
    Open Edge Browser and navigate Bing.com
    Make sure you are signed in with your user account, then click on the action button (top-right corner) and click on Settings.
    In the Settings menu of Bing, go to the Search section and set SafeSearch to Off.
    Hit Save button at the bottom of the menu and see if Safe Search is now disabled when using Bing.
    ______________________________________________________________
    Here’s a quick guide on how to disable Safe Search for Google search engine if you also need it:
    Open Microsoft Edge or Internet Explorer and access the Google Search Engine.
    Make sure you are logged in with your Google account and search for something.
    Above the search results, click on Settings and then choose Turn off SafeSearch.
    _______________________________________________________________
    In the event that this method wasn’t effective in disabling Safe Search, move down to the next method below, which is checking for updates on your windows and Edge browser.
    Thanks.
    This sorted my issues out. I thought this was a problem with Edge!
    Roy
    2023-09-13T20:25:30+00:00
    I have windows 11 pro. No education version.
  4. Don Varnau 19,930 Reputation points Volunteer Moderator
    2023-08-20T23:09:59+00:00
    It doesn't work. I tried the method you provide but the SafeSearch still stuck as Strict.
    Loay Apo Mahmood suggested that you search with google, not Bing. You should be
    able to turn off SafeSearch with google.
    https://www.google.com/safesearch
    Don
    Thank you Don. When I visit www.google.com/safesearch, it shows I have no right to adjust the setting. it needs me to verify something. Then I click the more information below, it shows a verification things, which need I to fill in the name, date of birth and phone number. The fact is I am Chinese and take a long vacation in South Korea, so I do not have local phone number, so could you please give me more hands, thanks in advance.
    Regards,
    You can almost certainly give Google someone else's cell number, so long as that person can tell you, very quickly, what code Google sent.
    Only guessing... at https://myaccount.google.com/personal-info?hl=en does Google have one or more alternate email addresses for you? There may be a way to have a code sent to an alternate email address instead of a cell phone.
    Don
    2023-08-20T13:57:55+00:00
    I have narrowed this issue down to either the router or ISP.
    To fix:
    • Go to your computer Settings > Network & internet > Wi-Fi.
    • Look for Random hardware addresses and turn On.
    • Then go to Manage known networks.
    • Select the networks you use.
    • Find the same thing - Random hardware addresses and select On.
    • Make sure you disconnect and reconnect to your Wi-Fi after changing the settings.
    I had to do this both places for it to work.
    Hope that helps!
