Are Surface Headphone 2 ear pads compatible with first version of Surface Headphone?
2022-09-20T01:54:41+00:00
I'm looking for Ear pads for first version of Surface Headphone (ear cups rotate 90 degrees). I followed this instructions to get a replacement earpad:
Replace the ear pads on your Surface Headphones (microsoft.com)
When I select "Category:Accessory", then under "Issue Type" it only lists Cable and Case, there is no Ear Pad, see image below:
I imagine it is no longer available. Are the ear pads for the Surface Headphones 2 compatible with the first version of Surface Headphone?
Surface | Surface Headphones | Other
    2022-09-20T14:12:57+00:00
    Hi Cometssun,
    Thank you for reaching Microsoft Community.
    in creating an order for replacement Ear Pads for the Surface Headphones, order should be created under the exact version of the headphones to make sure that you will receive the correct pair for the headphones version that you have. In this case where the accessory (ear pads) is not showing up on your end, it would be best to contact our live support for options and for further assistance. You may contact them through the numbers listed in Global Customer Service phone numbers (microsoft.com) under For Business users. This works with Home users also, just select Surface then Home as a type of user in the IVR prompt. You may also reach them through this page: Contact Us - Microsoft Support following the steps below:
    1: Go to Contact Us - Microsoft Support and sign-in your personal Microsoft Account
    2: To make sure you are using the correct locale of the page, click the Globe icon on the lower-left corner of the page then select the country you are in.
    3: Click Get support
    4: On the Describe your issue box, type in Contact support then click on Get Help
    5: Click on Contact Support at the bottom
    4: On the next page, select Surface then Technical support then choose your Surface model and click on Confirm
    5: These options should appear depending on which is available on you country. It would also show the available time of support if in case you accessed the page out of the time of operations.
           You may select **Provide your phone number and a support agent will call you** option and you will be ask to select and confirm your phone number then click **Confirm**. You will then receive a phone call from support in a while.
          Selecting **Chat with support agent in your web browser** will ask you to confirm the email address associated with your Microsoft Account then click **Confirm**.
    Kind regards,
    Marrion
