@Crest_Z, you say in Step #3 to use a USB Recovery Drive, to "Press and hold the volume-down (-) rocker". I don't have one of those on my Microsoft Surface Laptop 3. Can you advise what else I'm supposed to press? There are volume controls on the keyboard F keys. F2 is mute, F3 is volume down, F4 is volume up. Should I use the F3 button instead of having no volume rocker?
Surface Laptop 3 - When watching videos audio precedes the video
I recently just purchased a Surface Laptop 3 15" AMD/8GB RAM a couple of days ago, and have noticed this issue since I've started using it.
Whenever a video is played either on Twitch, YouTube, Netflix, etc. after about a minute the audio will proceed to get further ahead of the video causing a horrible desync. I've used Chrome, Firefox, and Edge all to no avail.
I've tried updating the drivers on the laptop through the Microsoft site with the MSI installer, but that didn't work. I also tried to change the Realtek driver to the standard high definition driver but then the sound wouldn't even play so I had to revert that. I'm assuming that this is an issue either with the graphics not having updated drivers or the audio driver not being updated. I can't find updates for either of these drivers.
Has anyone else experienced this issue?
Surface | Surface Laptop | Sound and camera
2020-05-12T20:54:09+00:00 -
2020-05-13T08:57:36+00:00 Hello. Press the turn-on button and F3. F3-F4s work as a reduction and increase in volume.
2020-05-14T16:42:08+00:00 I have the exact same problem after getting a replacement model, this is unacceptable at this price point.
Microsoft needs to do something about this as soon as possible.
2020-05-14T18:39:04+00:00 I also got a replacement for another reason and here is the problem. When I download the file the sound stutters and cracks. I did a clean installation with USB and now I don't have this problem. I think it's the fault of the firmware update.
2020-05-22T17:58:51+00:00 I'm not sure how to "raise the issue." I was hoping that would happen here by MS support people viewing these posts.
I installed all surface and windows updates AND the drivers via Microsoft's Surface 3 page for AMD chips from the page below.. and am still having sync problems within minutes of watching videos.
https://www.microsoft.com/en-us/download/details.aspx?id=100428
Totally unwatchable for streaming any video.
Microsoft support, PLEASE advise!
