SURFACE LAPTOP 3 - Overheating when charging and excessive Fan Noise
2020-01-07T23:58:07+00:00
Edit: 16 Jun 2021
Laptop is going OK - not much fan noise or heating as I haven't been using it much. mostly my work laptop
Got a better data USB C to USB C cable to plug into the dock and using a Lenovo Dock Gen 2 for the additional screen, think they are helping in better handling and keeps fans not to rev so much
Being my 3rd laptop (replaced 2 before) battery is performing better than the other two. Haven't run the full tests yet - still in progress to test real word batt life (office work, no games, no memory or cpu intensive apps)
Edit: 17 Feb 2021
Well, this 3rd laptop replacement is not as bad as the other two, however, the rocket engine fan noise is not completely gone.
this laptop is for light use only, any slightest workload "WHEN hooked up to an additional monitor" + Microsoft teams video call, 3-word documents, 2 webpages, this laptop cannot handle. It runs however fans rev up and won't stop until we close a few applications or disconnect additional monitor.
I think its the quick charging or charging which using additional display via display USB-C. Not much was done during the testing phase.
I hear dell XPS's and some other laptops rev fans too, however only when there is significant load, not just basic office work.
Example: I had sticky notes, 1 webpage, and a TEMAS interview video call: Laptop fans did not stop revving at max speed until the end of the interview and I closed all applications.
For this time there is nothing more I want to do - there is no fix for this, so i will have to s*C* it up and make a better decision next time.
Edit:28 Oct 2020
Nothing changed its still overheats when plugged to an external display. Fans still rev high when on Microsot teams meeting or charging. Laptop battery looks like it gave up (3 to 5 hour max) on light use. What a shame this issue is not getting enough attention.
Edit: 28 Aug 2020
No change - Laptop still goes crazy when plugged to an additional screen
All Microsoft Stores are temporarily closed until further notice. So I have to escalate this again to Microsoft
Edit: 17 Apr 2020
The issue still continues, Couldn't attend MS Store because of COVID lockdowns.
At this stage im hoping they can fix this via software patch. However, after research, this has been a problem for a few MS products (charging, especially fast charging)
Edit: 21 Jan 2020
Still did not go to Microsoft store. With this COVID 19 going on, working from home most of the time.
I will give away my laptop to the store soon to test.
Biggest change I noticed.  Battery is being effected. When ever the laptop is hot during couple of hours of work connected to dock.... remove from the dock....u get 3 hours or so max on full battery... guessing due to excessive heat I guess.
I tried multiple times charging with power adapter. Works fine without issues, no heat, battery lasts longer a little. Daily heating issue is causing battery to deterioate quickly
Surface Laptop 3 - 13inch, i5, 8GB, 256GB SSD.
Surface laptop overheating on every charge - even with no applications running. Brand new laptop, room temperature is under 21 C. After plugging in the charger, if you listen closely near the exhaust vents - there is a faint static electric noise, not to mention is scary as i don't want to use this anywhere close to me.
Laptop has already been replaced with a new one, still same issue. With some research a lot of people are experiencing the same issue. Any solution for this ?????
Surface | Surface Laptop | Power and battery
    2021-08-24T06:30:35+00:00
    I returned mine for this reason. I am buying another MacBook air
    2021-08-24T05:34:02+00:00
    Same model and same issue I experienced from the first day I opened it .. and I’m totally regret changing from MacBook to Microsoft surface .. first time and will be the last time for sure, so disappointed, didn’t expect a pricey laptop like that to be that noisy and HOT .. I’m sure I can fried eggs on it .. getting a stove will be more cheaper and more helpful for sure
    I understand that feeling. Don't get me wrong Windows 10 is a great OS and this is touch screen too. Not many ppl like touching screens though.
    Make sure its up to date with updates, don't bother changing registry settings and other tricks u find on internet it wont change much. I changed 3 laptops and saw cooling increase by 10% only. I finally came to terms with this laptop.
    one thing which helped ppl i see was to lower the CPU to 99 or 98% max. Worth a try again think it needa some admin tweaking, not hard and plenty of online tutorials.
    Have fun. Stay safe.
    2021-08-24T05:03:30+00:00
    2021-08-01T15:58:42+00:00
    For what its worth I think I have found a partial solution to the heating up. I experimented and found that heating up is only a problem if I used the USB-C port.
    However the way to stop it heating up is to make sure you do not disconnect whatever you put in the C port (even just the cord or port you stuck in to convert it to USB, etc) until AFTER you turn off the computer.
    It does not seem to matter when you first connect the USB-C cord...before or after the computer is turned on. I tried the above several times and this seems to work. It does not seem to matter whether the power cord is in or out at any time in this process.
    Works for me and now I can keep my Surface. Hope this helps someone.
    2021-07-03T20:56:53+00:00
    You should flip it over while charging..this will dissipate the heat or get a cooler for the bottom.
    I am happy with it because I have had little problem with this laptop. Maybe you should get a bigger bulky one that has a bigger fan
