SURFACE LAPTOP 3 - Overheating when charging and excessive Fan Noise
2020-01-07T23:58:07+00:00
Edit: 16 Jun 2021
Laptop is going OK - not much fan noise or heating as I haven't been using it much. mostly my work laptop
Got a better data USB C to USB C cable to plug into the dock and using a Lenovo Dock Gen 2 for the additional screen, think they are helping in better handling and keeps fans not to rev so much
Being my 3rd laptop (replaced 2 before) battery is performing better than the other two. Haven't run the full tests yet - still in progress to test real word batt life (office work, no games, no memory or cpu intensive apps)
Edit: 17 Feb 2021
Well, this 3rd laptop replacement is not as bad as the other two, however, the rocket engine fan noise is not completely gone.
this laptop is for light use only, any slightest workload "WHEN hooked up to an additional monitor" + Microsoft teams video call, 3-word documents, 2 webpages, this laptop cannot handle. It runs however fans rev up and won't stop until we close a few applications or disconnect additional monitor.
I think its the quick charging or charging which using additional display via display USB-C. Not much was done during the testing phase.
I hear dell XPS's and some other laptops rev fans too, however only when there is significant load, not just basic office work.
Example: I had sticky notes, 1 webpage, and a TEMAS interview video call: Laptop fans did not stop revving at max speed until the end of the interview and I closed all applications.
For this time there is nothing more I want to do - there is no fix for this, so i will have to s*C* it up and make a better decision next time.
Edit:28 Oct 2020
Nothing changed its still overheats when plugged to an external display. Fans still rev high when on Microsot teams meeting or charging. Laptop battery looks like it gave up (3 to 5 hour max) on light use. What a shame this issue is not getting enough attention.
Edit: 28 Aug 2020
No change - Laptop still goes crazy when plugged to an additional screen
All Microsoft Stores are temporarily closed until further notice. So I have to escalate this again to Microsoft
Edit: 17 Apr 2020
The issue still continues, Couldn't attend MS Store because of COVID lockdowns.
At this stage im hoping they can fix this via software patch. However, after research, this has been a problem for a few MS products (charging, especially fast charging)
Edit: 21 Jan 2020
Still did not go to Microsoft store. With this COVID 19 going on, working from home most of the time.
I will give away my laptop to the store soon to test.
Biggest change I noticed.  Battery is being effected. When ever the laptop is hot during couple of hours of work connected to dock.... remove from the dock....u get 3 hours or so max on full battery... guessing due to excessive heat I guess.
I tried multiple times charging with power adapter. Works fine without issues, no heat, battery lasts longer a little. Daily heating issue is causing battery to deterioate quickly
Surface Laptop 3 - 13inch, i5, 8GB, 256GB SSD.
Surface laptop overheating on every charge - even with no applications running. Brand new laptop, room temperature is under 21 C. After plugging in the charger, if you listen closely near the exhaust vents - there is a faint static electric noise, not to mention is scary as i don't want to use this anywhere close to me.
Laptop has already been replaced with a new one, still same issue. With some research a lot of people are experiencing the same issue. Any solution for this ?????
Surface | Surface Laptop | Power and battery
    2021-02-01T15:29:05+00:00
    I have the same problem. SL3 i7.
    Problem is when i connect my 34" Ultrawide monitor thru USB C to DP cable and charging at the same time. Fans will go overdrive, and the SL3 is getting really really hot and cause the SL3 to get really sluggish.
    2 options that I've been doing as work around
    1. Remove external monitor - unplug the usb c. Temperature goes down and fan return to normal. Downside, i cannot use my lovely 34" ultrawide monitor.
    2. Remove the charging cable. Use battery whenever i have my external monitor connected - Temperature ok, fan also ok. Downside, can only use the labtop depending on the battery level. So, i charge the labtop whenever i'm on the break.
    I haven't try to use surface dock and see if this would solve the problem.
    2021-01-29T06:10:35+00:00
    I've encountered this issue for about half a year. Recently I fully re-install the surface laptop 3 via recovery image from https://support.microsoft.com/en-us/surfacerecoveryimage. Because my device not only making fan noise, but also the store app stop working. BTW resetting the device does not fix any of this. And it's time consuming to migrating all the data and update the Windows to the latest version(20H2). I kind of notice the fan noise doesn't appear as often as its used to be after the reinstallation.
    I don't encourage any of you try this out, because I can not guarantee 100% fix the issue.
    I'm just telling how I resolve this issue by accident. If you have tons of time, you can try this out.
    Just do it at your own risk.
    2021-01-19T05:26:02+00:00
    Hi guys, I finally got this issue solved. After one day I cannot boot up the machine, I send back the laptop to the Microsoft service factory, they had made a replacement of the mainboard. After that the temperature had never above 60 °C when full load, and  normally below 40 °C.
    2021-01-14T12:13:52+00:00
    I also have the same issue since i bought the Surface Laptop 3 last year in february.
    The temp and Fans are all in normal condition when not plugged to charge.
    But when i plug the charger into my surface it starts go crazy!
    The Surface get so hot and temp is really high, the fans are on max mode and really loud.
    Until i take off the charger. Then everything starts getting normal.
    Also then my surface is plugged in when its in standby sometimes it just randomly starts to activate its fans? This is a little bit scaring me.
    2020-12-31T16:52:35+00:00
    I have the same issue. I have returned 2 already and I'm just setting up the third. It is so hot I could cook an egg on it. The service over the phone is good. But how many laptops do I have to change over???? The said after the second had the same issue that they refund on the third try. I'm guessing I'm heading in that direction.
