SURFACE LAPTOP 3 - Overheating when charging and excessive Fan Noise
2020-01-07T23:58:07+00:00
Edit: 16 Jun 2021
Laptop is going OK - not much fan noise or heating as I haven't been using it much. mostly my work laptop
Got a better data USB C to USB C cable to plug into the dock and using a Lenovo Dock Gen 2 for the additional screen, think they are helping in better handling and keeps fans not to rev so much
Being my 3rd laptop (replaced 2 before) battery is performing better than the other two. Haven't run the full tests yet - still in progress to test real word batt life (office work, no games, no memory or cpu intensive apps)
Edit: 17 Feb 2021
Well, this 3rd laptop replacement is not as bad as the other two, however, the rocket engine fan noise is not completely gone.
this laptop is for light use only, any slightest workload "WHEN hooked up to an additional monitor" + Microsoft teams video call, 3-word documents, 2 webpages, this laptop cannot handle. It runs however fans rev up and won't stop until we close a few applications or disconnect additional monitor.
I think its the quick charging or charging which using additional display via display USB-C. Not much was done during the testing phase.
I hear dell XPS's and some other laptops rev fans too, however only when there is significant load, not just basic office work.
Example: I had sticky notes, 1 webpage, and a TEMAS interview video call: Laptop fans did not stop revving at max speed until the end of the interview and I closed all applications.
For this time there is nothing more I want to do - there is no fix for this, so i will have to s*C* it up and make a better decision next time.
Edit:28 Oct 2020
Nothing changed its still overheats when plugged to an external display. Fans still rev high when on Microsot teams meeting or charging. Laptop battery looks like it gave up (3 to 5 hour max) on light use. What a shame this issue is not getting enough attention.
Edit: 28 Aug 2020
No change - Laptop still goes crazy when plugged to an additional screen
All Microsoft Stores are temporarily closed until further notice. So I have to escalate this again to Microsoft
Edit: 17 Apr 2020
The issue still continues, Couldn't attend MS Store because of COVID lockdowns.
At this stage im hoping they can fix this via software patch. However, after research, this has been a problem for a few MS products (charging, especially fast charging)
Edit: 21 Jan 2020
Still did not go to Microsoft store. With this COVID 19 going on, working from home most of the time.
I will give away my laptop to the store soon to test.
Biggest change I noticed.  Battery is being effected. When ever the laptop is hot during couple of hours of work connected to dock.... remove from the dock....u get 3 hours or so max on full battery... guessing due to excessive heat I guess.
I tried multiple times charging with power adapter. Works fine without issues, no heat, battery lasts longer a little. Daily heating issue is causing battery to deterioate quickly
Surface Laptop 3 - 13inch, i5, 8GB, 256GB SSD.
Surface laptop overheating on every charge - even with no applications running. Brand new laptop, room temperature is under 21 C. After plugging in the charger, if you listen closely near the exhaust vents - there is a faint static electric noise, not to mention is scary as i don't want to use this anywhere close to me.
Laptop has already been replaced with a new one, still same issue. With some research a lot of people are experiencing the same issue. Any solution for this ?????
Surface | Surface Laptop | Power and battery
    2020-06-05T13:26:48+00:00
    I had the same issue with my surface laptop 3 I had bought 2 weeks before. I tried following Microsoft recommendations but it didn't fix anything. I returned my laptop and got a new one. They noticed also that my charger made a weird electricity noise. The new one still heats a little, even though less than the previous one.
    However I noticed that the laptop was overheating mainly when I used it while charging it above 70% of battery. At that point, my fans start running harder and making a lot of noise. So now when I want to charge the computer above 70%, I do it when I don't use it. Otherwise I just unplog the charger. That's how I manage the issue because regardless of it, I really like this computer. I still think that for a product of this price and standard, the overheating issue, and heavy fan noises are absolutely not normal.
    2020-06-05T12:13:23+00:00
    Yeh, I sent my laptop back and got a refund. There is no way I am spending that money on a device with that kind of issue. Mine overheated so much once, the screen started to shimmer. This happened on my Surface Pro 4 BTW, so there is precedent. Nope, MSFT has to do better than that.
    2020-06-05T09:23:25+00:00
    i have the same issue with my new laptop it is overheating whenever it is charging i followed all the recommended steps by Microsoft and it did not fixed the issue, and after 2 weeks i got a black screen with Microsoft logo, i returned my laptop and they gave me a new one they said it is a hardware issue. but still even with this new laptop it is overheating when charging. is it a factory issue with this model ? what is cussing this problem with surface? i am afraid that i will get a black screen with the replace laptop as will.
    2020-05-27T14:24:45+00:00
    So we have it right.  Can u share the social media link ?
    https://www.instagram.com/surface/
    You'll find my comments there. :)
  5. Deleted
