Surface laptop 3 fans running loud when laptop is plugged in
2019-11-17T19:40:03+00:00
Hello. I have been having this problem with my Surface laptop 3 where when I play a light game (like Minecraft) with the laptop plugged in the fans become extremely loud. However when the laptop is not plugged in the fans don't get even close to being as loud... Can someone help me solve this problem?
Surface | Surface Laptop | Power and battery
2019-11-18T17:57:09+00:00
Hi 8gigLiam,
Thanks for reaching Microsoft Surface Community. We thank you for taking advantage on our new Surface Laptop 3. Definitely this is not the experience that we want you to have. We do have some few questions to have this isolated and some suggestions could lead us to a resolution.
When your on Battery, you have mentioned that you the fan is not that loud, But if you check on the battery slider are you on "Best Performance" while your in game?
You can adjust how you want your CPU to perform, by selecting the battery icon on the task bar and adjusting the power mode. Setting the power mode to Recommended throttles the CPU and helps keep it running cooler with less need of assisted cooling. While a setting of Better performance or Best performance will allow the device to run more quickly, it will also allow the fan to come on more often to keep the CPU cool and performing it's best.
Is this the 15" or the 13.5" Surface Laptop 3 for the Graphics"
If this is the 13.5" what's the processor?
We have :
Quad-core 10th Gen Intel® Core™ i5-1035G7 Processor
Quad-core 10th Gen Intel® Core™ i7-1065G7 Processor
You can check this by going to Task Bar search box and Type there "dxdiag".
Looking forward on your response. Please keep us posted.
Regards,
Edd
68 additional answers
    2020-04-01T09:13:35+00:00
    Haha I'll be damned! I tried my old MBP charger and it actually works!
    Colour me well and truly baffled. After a few minutes the fan noise eventually died down. Thank you so much!
    2020-03-31T18:28:58+00:00
    I am having the same issue as well. Anyone found any solution?
    2020-03-31T17:32:11+00:00
    One thing helped me a little, not sure if it really can help you. I changed the resolution of my screen from Recommended 2256x1504 to 1620x1080. Afterwards changed the size of text, apps, and other items from 150 to 100. These changes do not change the display view, all remain the same, but the fan began working less loudly.
    2020-03-31T14:48:31+00:00
    I haven't tried it yet as I have found a temp solution via use of a macbook charger, but are you going through regedit?
    Hit the Windows key, type "regedit", hit enter, and then follow the suggested file path of HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power to get to the right setting.
