You can check your battery usage history in the Settings app(Under System-> Battery Saver ->Battery use) where you might be able to find the culprit of battery drains.
Surface Book Battery Life - what are you getting
Hi everyone,
I am not doing anything to intensive with my Surface Book. Web, email, onenote, outlook. I am not getting anything near 12 hours of battery life and 4 if i am lucky.
Right now it says I have 33% battery life and have an 1 hour and 26 minutes remaining??
What are you getting?
2016-02-29T04:46:54+00:00 -
2016-03-18T11:05:24+00:00 Hi guys,
I have been using my SB for 1 month and can only get 6 to 6.5 hours battery life with the keyboard attached. This is with having maybe 3-4 tabs in Edge open and Excel/Word open as well. Microsoft Support told me this was normal battery life, but I simply cannot believe this, as every single review I have come across says it should get at least 10 hours.
Anyone else having the same experience?
Andrew
2016-04-14T01:55:09+00:00 Yeah I've got 5 hours consistently on the laptop with some web browsing / excel / one note. I think I got a dud, has anyone gone through the warranty process with the battery?
2016-04-14T02:08:54+00:00 I'm pretty sure with the battery non-removeable they would just swap out for a new SB. But we all know the battery issues are with every SB device since launch including new SB's. Microsoft is apparently still working on a fix. There are workarounds to improve battery life but I'm sure you've seen those in the forum.
