Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-07-27T13:24:54+00:00
    Thank you for your answer.
    If the issue continues after this, what would you recommend to do? Return the device and swap for another one or wait for a fix that solves it?
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-07-27T13:41:14+00:00
    tough call to make. how often is the unexpected hibernate occurring?
  3. Deleted
    2017-07-28T17:12:58+00:00
    mine does that too.
    I believe it is supposed to do that it is called "adaptive hibernation".
    if you don't want it to hibernate go to settings > system > power and sleep and turn off the
    "save me power when my device knows I'm away.
