Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-07-24T20:48:00+00:00
    I'm still experiencing the "black-screen" problem, July 24th.
    2017-07-25T06:52:52+00:00
    I had read about the problem but had no problem myself until the update was installed. In my case it doesn't happen suddenly, but I put the computer to sleep and when I go back to use it sometimes it is off, sometimes it is hibernating even though I have hibernate to never go into effect, sometimes it is ok, just sleeping.  So in other words, it is behaving erratically.
    best,
    2017-07-27T07:07:18+00:00
    Is the new firmware update (Surface - Firmware - 233.1763.257.0) ?
    This is what Windows Update reported was the installed firmware update.
    ""Surface - Firmware - 5/18/2017 12:00:00 AM - 165.0.1.0""
    Is this the correct one for the fix? Even though this is installed the Surface Pro shuts down itself.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-07-27T10:21:03+00:00
    go to https://www.microsoft.com/en-us/download/details.aspx?id=55484 and
    download and run the MSI file that is offered for download. This will force
    install anything that is missing.
