Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-07-14T05:19:32+00:00
    Can I ask if anyone has successfully updated the graphics driver (using the .zip version) and subsequently has not had any spontaneous sleep events ?
    2017-07-14T05:23:52+00:00
    I updated the driver, and the random hibernation still happens, though at a much lower frequency.
    2017-07-14T05:45:19+00:00
    Ok. One more step that might help:
    Open the Intel Graphics Settings (right click desktop).
    Go to the 'Power' settings.
    Under 'Battery' disable the 'Display Power Saving Technology'.
    Apply changes.
    2017-07-14T10:33:12+00:00
    Here is an official MSFT page I found about this firmware update. It says "This update revises system power reporting". It doesn't say anything about fixing any bugs though.
    That page says that it is downloaded automatically but has not happened here so far...
