Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-07-12T12:22:09+00:00
    Thanks SnakeJam,and your method for solving the random shutting down seems work,I use it for a day without any shutting down.
    2017-07-12T14:21:28+00:00
    Hello Everyone,
    7/12 Update: Just wanted to provide additional information that this fix was not included in the 7/11 Windows update, as testing still continues. I will update this posting when the update is available, also the Surface Pro Update History page will also be updated with the details when it launches.
    BryanH [MSFT]
    2017-07-12T14:54:26+00:00
    I am also having this problem. Very frustrating that my new device keeps shutting off... there is not a Microsoft store within two hours of where I live :(
    2017-07-12T15:12:51+00:00
    Just try SnakeJam ' method,it works for me so far without any random shut down for a day.
    Thank you for your advice: I will do it if no other solution will be available.
    It's a kind of last resosrt and I'm confident it works fine, but it actually removes the possibility of hibernation which is not terrible, it's only that if I can help it...
