Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-07-08T11:26:30+00:00
    Well the the Software Repair tool didnt help. From the Online chat of Microsoft i was told to try wit the USB recovery and if it doesnt help i should change it for a new device. Did anybody used the step with the USB? I was told, i have to save all my datas or i will lose them all.
    2017-07-08T11:41:30+00:00
    Can I suggest looking at this as a possible solution to the hibernation issue (see post by user eckka):
    https://answers.microsoft.com/en-us/surface/forum/surfpronew-surfdrivers/surface-pro-2017-resume-with-external-monitor/5aafe641-e0f8-4f06-8b44-d42308134e79
    This post is to do with an external monitor issue but seems to have also helped (so far) with other Surface display issues I was having including hibernation.
    Key point is to swap out update KB4022716 for update KB4022725.
    2017-07-08T12:59:58+00:00
    Same Problemmmm!!   i've already tried to change every single settings i can possibly think of, turning off the Window Hello, change the  Power Settings, change the Display Saver settings etc etc etc....
    Nothing works, it still schutting off randomly
    2017-07-08T13:55:29+00:00
    On my SP I already have the KB4022725 update (I don't know if on my machine there has ever been the 716 one since I made my first updates on the 20th of June) but it keeps hibernating.
    I have the impression that the problem is becoming worse with time, it tends to hibernate more and more frequently, but that could be just an impression... anyway, today I left it idling two times and both times in less than 30 minutes it went to hibernation (my settings are hibernation after 2 hours both on battery and plugged).
    In general I would say, based on my personal experiences and what is reported here, that the problem is "in the PC", no settings change or accessories removal or software configuration seems to make any difference.
    To me it often happens running Word 2013, but it also happens with Chrome or even with no program running, while on the desktop screen and idling.
    Two minutes ago I was on Chrome, I made ALT-TAB to go to Word on an open file and 2 seconds later, hibernation. I repeated the same steps another 3-4 times, no problem... no way to reproduce the incident...
