Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-07-01T17:01:47+00:00
    I'm now trying the idea of shifting my power settings from Balanced to Better performance. See if that works. Setting up my own power plan with Balanced selected didn't work either.
    Can we have a fix for this please - otherwise I'll have to send this SP back :-(
    2017-07-01T17:21:10+00:00
    Hi everyone,
    We are aware of a small group of customers reporting a scenario with their new Surface Pro in which the device inadvertently hibernates. We are investigating this issue.
    BryanH [MSFT]
    [Mod Edit: Marked as Answer to raise to top of thread.]
    Also Bluetooth steps working
    "The local adapter does not support an important Low Energy controller state to support peripheral mode. The minimum required supported state mask is 0x491f7fffff; got 0x1fffffff. Low Energy peripheral role functionality will not be available."
    2017-07-01T19:01:32+00:00
    I just had this happen twice in the last hour. I bought my Surface Pro about two weeks ago and this is the first time I've encountered this issue -- now twice in short succession.
    I have the i7/16Gb/512Gb device.
    The unprompted hibernations happened when using the device with only a bluetooth keyboard attached -- no other peripherals.
    I've looked in the event viewer, but nothing related to thermal events is listed in the last hour. The device isn't warm to the touch and the fan's not on, so I don't think it's related to overheating.
    2017-07-01T19:06:33+00:00
    Still working for me. Haven't had a hibernation or issue in four days now.
