Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-06-30T19:28:59+00:00
    I never leave my PCs unattended so I turned everything to Never sleep. Rarely do I use sleep except occasionally putting the PC to sleep by closing the cover.
    Note: This only worked when I created a different power profile. I tried the same Never settings under the default balanced power profile and still experienced the random shutting off.
    2017-06-30T19:30:36+00:00
    That microsoft releases a product this way, multiple times no less, is bizarre.
    2017-06-30T19:36:16+00:00
    On the advanced power options if Balanced is locked there's a link towards the top of the panel you can click to unlock the profile so you can make the plan changes. It's a strange setup for sure. The fact you have to wade so deep to find these settings is unfortunate.
    EDIT: Since I created a custom power profile I haven't experienced the powering down or shutting off issue. It appears to work on power as well as on battery.
    2017-06-30T20:50:40+00:00
    My SP just went into hibernation when it was sat there for a few seconds doing nothing. The hardware troubleshooter fix hasn't solved the problem.
    I'll try changing the power plan.
    Can we have an official fix please?
