Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-06-30T14:21:09+00:00
    In the same boat, happens all the time and I cannot figure out the cause no system errors in Event Viewer or anything, brand new device..
    2017-06-30T15:58:21+00:00
    the SP4 won't wake up, the new SP won't work.
    What the twins!
    2017-06-30T15:59:53+00:00
    you can create custom plan on surface? I believe it's blocked, the Balanced is the only choice.
    2017-06-30T16:12:10+00:00
    Yes, you can create a custom power plan. Go to "Power & Sleep" on settings. Then select the hyperlink to "Additional power settings." That takes you to the old familiar screen where you can create a custom power setting of your choice.
