Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2018-01-13T11:25:23+00:00
    I have the same problem. I hope there will be an update available soon.
    2018-01-13T11:43:17+00:00
    I had the problem, but took all three best advises on this thread and it solved my problem.
    I installed the Surface Pro Drivers and Firmware package that has been posted as a solution to this problem (could be all that is needed). For good measure, I also explicitly changed some of the power settings back and forth and saved the settings again. And did a soft reset + entering BIOS setup and exited + saving changes (no real changes made), which someone has posted previously.
    In totality, I have seen the problem since, and it's been two weeks now.
    2018-01-14T10:33:24+00:00
    I have no updated on january 3rd to the latest Windows Update KB4045892 BS-Build 16299.192 and it seems like the problem might be solved because there was no sudden shut down since. But I will update if the problem returns.
    2018-01-17T00:42:24+00:00
    continously going in standby...surface pro bought in december...ashamed ...1600euro...but WHAT SERIOUS BRAND YOU ARE?
    be fair..take all surface back and send a new one without poblems ,the price you ask requires them
    THANK YOU
