Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-09-23T16:17:58+00:00
    I'm also seeing this problem. My Surface Pro 2017 randomly goes into sleep mode while I'm activaly working with it. I've checked Windows Update however and my computer is fully updated.
    2017-09-25T01:46:45+00:00
    after the update the issue still not fix....
    Windows 10 1703 (15063.608)
    New Surface Pro i5/8G/256 (already run Surface Diagnostic Toolkit to check the driver and firmware update)
    2017-09-26T15:08:37+00:00
    It was working fine after the update and 2 weeks ago began the problem? Any ideas why back the problem?
    2017-09-26T16:15:56+00:00
    The event viewer on my surface pro gives this error message:
    The system was hibernated due to a critical thermal event.
    Hibernate Time = 2017-09-19T04:37:29.940120500Z
    ACPI Thermal Zone - Inter(R_ Dynamic Platform Thermal Framework
    _HOT - 375K
    It's happening no matter what peripherals are in use / not in use.
    I'm almost certainly going to return mine for a refund. The question is - do I buy another one? Do they all suffer from the same problem or have I just been unlucky with the one I have?
    This more hints to a hardware failure, did other people report this before? So the thermal diode reported a temperature of 375°K = 102°C, where the computer turns off automatically for safety reasons I guess. So maybe a lot of devices have a faulty thermal diode and you wont be able to fix it via software but only if you replace the unit. Or this was just a single user event, and your tablets CPU was indeed at 102°C, for whatever reason.
