Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-08-08T09:50:28+00:00
    this is a Surface ONLY forum to support Surface branded devices.
    >>Why is this marked as a Surface only problem!
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-08-08T09:59:37+00:00
    Cool story, why are the MVP actually the most useless people of getting help always in this forum? I can repeat the question again, you can read it a second time, maybe you understand it then:
    Why is this marked as a Surface only problem? BECAUSE IT IS NOT.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-08-08T10:17:21+00:00
    I understood you fine the first time. If you want help with hardware other than
    the Surface brand, you can post in the general Windows Forum. Use a topic like
    "Dell Venue 11 Pro 7140 hibernates from inside normal sleep". And you can also
    try posting in the Dell forums to see if others have this issue with this
    specific hardware.
    If you just want to complain that this is not a Surface only issue, carry on..
    but if you actually want assistance, you will need to post elsewhere.
