Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-08-08T05:38:58+00:00
    Hey Everyone,
    7/14 Update: The fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
    BryanH [MSFT]
    7/12 Update: Just wanted to provide additional information that this fix was not included in the 7/11 Windows update, as testing still continues. I will update this posting when the update is available, also the Surface Pro Update History page will also be updated with the details when it launches.
    BryanH [MSFT]
    7/10 Update: Wanted to provide a quick update, we believe we have identified the issue, and are currently testing a fix that will be delivered via Windows Update.
    BryanH [MSFT]
    Does this fix the problem on previous Surface Pros as well? I have a 4-month old Surface Pro 3 that has the same problem. When it first happened, I found something from someone else who'd had the problem that said it only happened when he had the brightness at 100%, so I turned mine to 75% and it was fine for 3 months. Then 2 days ago, the same thing happened three times while at 75%. I lowered it to 50%, and it was fine again until today when it happened again.
    I usually get updates automatically, but there was one waiting for me. I'm not sure when it was released, but it should be the most recent one.
    So, anyway, should this fix my problem?
    2017-08-08T06:39:27+00:00
    Why is this marked as a Surface only problem!? I have the EXACT SAME issue on my Dell Venue 11 Pro 7140. Windows 10 randomly just decides to go hibernate from inside normal sleep... I have toggled the option under ac/dc on off on off several times for the "save energy if the device notices blah", but it doesnt care... it always goes hibernate randomly.
    IT IS NOT FIXED. Anyone help please?
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-08-08T09:50:28+00:00
    no - these updates are specific to the new Surface Pro. If you bought a new SP3
    four months ago, it is still under warranty. Go to a physical retail Microsoft
    Store if you are in the US and have them check it out. Otherwise contact
    support.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    support.
