Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-06-22T20:51:45+00:00
    It is clear more of us are having this unexpected behaviour. Will MS acknowledge there might be an issue and they are investigating?
    I'm not seeing much being said.
    Love my Surface though 😊
    Let's see if this helps Microsoft Respond: I was on track to buy my first Surface Pro this week, and then I read about this issue at Windows Central.
    I'm waiting to make my purchase until Microsoft acknowledges the problem and talks about solutions.  I don't feel confident making a purchase of this magnitude with it still up in the air whether this is a manufacturing defect, a driver error, or some other kind of unsolved bug.
    I was really excited about the new Surface Pro too -- this is a bummer.
    Microsoft, any timetable or strategy here?  Thanks.
    2017-06-23T00:35:36+00:00
    I've had 3 of these TODAY! All within about 10 minutes of each other.
    Log Name:      System
    Source:        Microsoft-Windows-DistributedCOM
    Date:          22-Jun-17 20:30:03
    Event ID:      10016
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          SYSTEM
    Computer:      Allen-SP5
    Description:
    The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
    {D63B10C5-BB46-4990-A94F-E40B9D520160}
     and APPID
    {9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
     to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
        <EventID Qualifiers="0">10016</EventID>
        <Version>0</Version>
        <Level>2</Level>
        <Task>0</Task>
        <Opcode>0</Opcode>
        <Keywords>0x8080000000000000</Keywords>
        <TimeCreated SystemTime="2017-06-23T00:30:03.259038700Z" />
        <EventRecordID>2074</EventRecordID>
        <Correlation />
        <Execution ProcessID="1016" ThreadID="8272" />
        <Channel>System</Channel>
        <Computer>Allen-SP5</Computer>
        <Security UserID="S-1-5-18" />
      </System>
      <EventData>
        <Data Name="param1">application-specific</Data>
        <Data Name="param2">Local</Data>
        <Data Name="param3">Activation</Data>
        <Data Name="param4">{D63B10C5-BB46-4990-A94F-E40B9D520160}</Data>
        <Data Name="param5">{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}</Data>
        <Data Name="param6">NT AUTHORITY</Data>
        <Data Name="param7">SYSTEM</Data>
        <Data Name="param8">S-1-5-18</Data>
        <Data Name="param9">LocalHost (Using LRPC)</Data>
        <Data Name="param10">Unavailable</Data>
        <Data Name="param11">Unavailable</Data>
      </EventData>
    </Event>
    2017-06-23T07:25:49+00:00
    i have the same probme with my surface pro 2017 m3.
    it randomly hibernates at any task (typing, movie, code etc.). if it does this i hit the power button and i see the windows boot logo.....after that im at the point where i was before. untill now i never lose data or work....
    2017-06-23T10:13:47+00:00
    Hi Becca05
    How has your system performed since the factory reset? Have you noticed another instance of the problem?
    Thanks for sharing.
