Surface Pro 2017 turning off or hibernating randomly!!!
2017-06-17T13:19:55+00:00
For some reason my new Surface is shutting off randomly. I check the setting and a few other things but it's still randomly turns off without warning. I'm losing some of my school work because of it. Is anyone else having this problem?
2017-06-29T00:49:55+00:00
Hey Everyone,
As of 7/14, the fix for this issue has completed testing and is now live, please go update your Surface Pro via Windows Update to get the latest download. You can obtain this fix by checking Settings> Update & security > Windows Update
The Surface Pro Update History page has been updated with the details of this release and the update is also available on the Surface Pro Drivers and Firmware page as part of the MSI installation package available for download.
BryanH [MSFT]
594 additional answers
    2017-06-28T17:35:31+00:00
    Yes, I installed the update this morning, and after that I got my first random hibernation.
    Since then I chatted to Microsoft help and ran the Hardware troubleshooter in Settings. This found a problem and applied a fix. After a restart, so far, no hibernation. Let's see.
    2017-06-28T17:19:21+00:00
    Microsoft surface just made an announcement about a new update for windows 10 to keep the surface performing at its best. Anyone tried it yet?
    The announcement is at the top of this forum.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-06-28T15:51:25+00:00
    can you turn it on with a two button restart?
    Step 1: press and hold the power button on your Surface for 30 seconds.
    Step 2: press and hold volume-up button and the power button on your Surface at
    the same time for at least 15 seconds, and then release both.
    The screen may flash the Surface logo, but continue holding the buttons
    down for at least 15 seconds.
    if you cant turn it on, return and repurchase.
    >>When I first try to log in it just shuts down and now wont turn back on!
    2017-06-28T15:12:30+00:00
    I am having the SP17 I5 8GB and also the problem, that it randmly goes to sleep.
    It happens at work in a bright room
    while using OneNote2016
    while writing with the Pen
    while watching a movie in a dark room
    while doing nothing, with OneNote2016 running in the background.
