Jeff - Super! Thank you for sharing.
I will set up a virtual machine (once I figure that out) to give it a try.
Don
I have been asking this question for some time now without a viable answer.
When I was convinced to buy this item, it came with a promise of 64bit emulator being very soon to follow, however this is now eight months later and still no idea how long we will have to wait.
I know that the emulator is currently available on the insider program, but all indicators are that its even more buggy than the somewhat limited 32bit emulator.
I'm surprised that Microsoft have not resolved the issues with this device as it would seem that they intend to peruse ARM technology in many future devices.
If the current state of play continues it could spell out disaster for this platform.
I have to say that there have been many updates for the pro x and it has improved over time, however many bugs and issues still remain and customer support for the pro x is at best very poor with the staff having little knowledge of the technical issues found on a daily basis.
Customer services have so far bricked the device on three occasions requiring hours of reloading and total loss of all data and without resolving the original problem (don't let them reset your device or set up phantom accounts) this doesn't work and creates more problems.
I have to say that given the choice again this device would not be on my shopping list.
The recent updates have made improvements and the device is now more stable than it was but without 64bit bug free emulator its very limited, Great looks and feel but don't judge the book by its cover,
If you intend to use only store apps and basic 32bit programs for surfing and emailing all is good, but for any serious use it fails badly at present, which is truly a shame as the device has great potential but is poorly supported from my own personal experience.
At present its only a little above windows other failed ARM devices using RT which of course is no longer supported.
Don
Well I took the plunge and switched my device to the insiders testing on the dev channel and upgraded the OS.
I actually don't have any productivity apps I need to use on it, so I tried a few 64-bit games instead. I found one issue that the x64 emulation at the moment can't get around, and that is if the app itself checks the architecture when it loads. For example, games that use Epic Games Unreal engine start to run and then throw an "unsupported architecture" message like this one:
I don't don't know if there is anything Microsoft can do about that, so it might be up to the developer. Honestly I'm not sure why Epic decided to put this check in, as doing some searching it seems it's come out since the x64 emulation arrived. I've seen posts about this from people using Windows on ARM devices like the Pro X, as well as Mac users with a device using Apple's new M1 processor running Windows in a virtual machine. I may file a support ticket with Epic asking for a way to ignore or bypass this check. Hopefully there won't be many apps like this.
I too tried the pre-beta, Dev version and so far all my apps work and work fine.
Of note, you will want to uninstall office and reinstall the 64bit version. That said, the 32bit version worked fine too.
Everything ported over smoothly. Fingers crossed, but haven't seen any incompatibilities yet.
Hi DomFriant, thanks for you advice with the Pro 7. I probably should have done more reserach. Actually I wanted a reliable mobile device, where I can use Office Applications also. I choose the Pro X because of the bigger screen. Now I am doing a further education in SQL. For this I wanted the SQL server. Not to run an app permanently. So I hoped that at least the lite version would run on the Pro X. I did not expect, that so many apps did not run on the flagship surface. But ok, hard learning:-) Lets see how is going with windows 11. I am also in the insider group, but I was nevertheless not able to run SQL server on my Pro X...
Windows has 35million programs and Microsoft store has over 600,000 apps. Please share how many programs/apps don't run on the SPX?
