Here is a thought for you performance geniuses, how come nobody ever asked for the Intel Core i7 "Haswell"?
If you are going to "upgrade", then upgrade! Don't stick with the same processor class. The performance difference between the 4200U and 4300U is that the 4300U can draw pretty pictures about 1.5 seconds faster. And that is about it.
I got a chance to compare the two with two different desktops yesterday when I was setting them up for use for other people and thought to set them side by side and compare them.
You will get the same performance from the tablets as well since they both have the same motherboard chipsets and data buss speeds.
Those machines are now in the hands of their owners and didn't have the time to do screenshots of the performance ratings and if I did, I would post them here.
If you are going to spend money and time on an upgrade, go for the next higher processor and not a slight upgrade of the current model.
Wonderful! We have an expert to help us who has compared the Intel chips and come to a quantitative conclusion! Please, direct me to where I can find this Core i7-equipped Surface Pro 2, and I will gladly throw money at it!
Edit: Assuming that you are talking to Microsoft instead of all of us while lecturing them on the speed differences between different classes of chips, a few reasons that they wouldn't go with an i7 might be battery life, thermal and space constraints,
and price given that ultrabook i7s probably aren't in as much demand as the i5s.
